![](images/spacer.gif) |
![](images/+Barco800.jpg)
Barco 500/800/801
AC input board
![](images/Barco800image025.jpg)
The AC input board contains the 110/220 volt jumper. Whichever side is facing up
when the board is installed is the voltage the set is preset to. The main AC
input fuses are also on this board. Once in a while these fuses will blow for no
reason, and once in a blue moon one of the fuse holders will develop a bad
contact with the fuse, and will blow multiple fuses. If this occurs, check the
fuse holder clips for discoloration, and if one side is darker than the other,
the board will need replacing.
