![](images/+Barco800.jpg)
Barco 500/800/801
RGB/Video output board(s)
The video output boards are identical for all three tubes. These boards can
cause a number of problems, including spot burn at turnoff, retrace lines (thin
diagonal lines running across the picture), and varying color balance as the
gain of the PC board changes. The WORST thing to do when you suspect a bad video
board is to tweak the trimpots on the board. A burnt tube is virtually
guaranteed if you tweak these pots.
![](images/Barco800image033.jpg)
A number of components usually need to be replaced if this board develops
symptoms. We stock spare boards to get you running quickly.
