![](images/spacer.gif) |
![](images/+Barco800.jpg)
Barco 500/800/801
Port 3 input board (not pictured)
Unlike the newer Barco 801/808 models, the port 3 input board of the Barco 800
is looking for an old and obsolete 5 volt signal level, used with
old 1980’s computers. A normal RGB signal from an HD box, scaler or computer
will not work through input 3. This board may be pulled out of the set if
desired, as it is not normally used when used in a home theater application.
RGB/Video switcher board
This board switches the projector between video, S-video and the RGB inputs.
A cable from the controller board switches the board between the various inputs.
This board is subject to failure if static electricity appears on the BNC input
connectors, and the symptom can be a missing color, one input is dead, or worst
case none of the inputs may work. This board is universal between all Barco 500
and 800 sets and may be interchanged. The 5 LED’s on the top edge of the board
give a visual indication as to which input is live. Note that without an input
signal, the LED’s may not light even though a particular input is selected.
![](images/Barco800image015.jpg)
Quad decoder board (not pictured)
This board converts the video input to an RGB level, and detects PAL, NTSC
and SECAM signals. There are no user adjustments on this board, and this board
rarely fails.
