    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Barco 500/800/801
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 7)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13
Out of all the parts in the projector, it's these power supplies that do fail the most as they are the hardest working part inside of the sets. The weak point on these supplies are the solder joints as shown below.
The above picture shows just a few of the weak solder joints that can crack over time. If you have a good soldering hand, pull out this power supply and carefully check all solder connections for cracks. The power transformer joints are very suspect as are the ones on the fuse holders.
The last point on our tour of the power supply is the adjustments.
In order to have a proper operating set, the + 17 volt test point needs to be set to 17 .0 volts, +/- 0.1 volt. This test point can shift in voltage over time, so periodic checking of this test point is recommended.
The final adjustment on this board is the master width control. While the Barco manual recommends a certain way to set this pot, I have had good results at all resolutions by going into the geometry menu and setting the width to 50%, and set the master width control so that the test pattern _just_ overshoots the face of the tube. The actual picture will then be within the tube face, and you’ll have plenty of width to play with at all resolutions within the geometry menu.
... Previous Page
Next Page ...
