![](images/spacer.gif) |
![](images/+Barco800.jpg)
Barco 500/800/801
HV quadrupler and splitter
![](images/Barco808HVsplitter.jpg)
As with all Barco sets, the HV quadrupler and splitter are sealed and are
not serviceable. Usually the faults in these units are internal and do not
result in smoke, arcing or other obvious symptoms. Note that the white cable
going to the splitter has TWO solder connections, the tip and the shield sleeve.
DO NOT cut this wire, it’s Teflon and is a nightmare to splice or strip. We
stock spare quads and splitters and can test yours in our test sets.
