    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Ampro 1500/2000
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 5)
Page: 1 2 3 4 5 6 7 8 9 10 11 12
Test/Text Generator:
There’s not much to say about this board. It generates the on board text messages where applicable, and also generates the test patterns.
I’ve found with the Ampro units that it’s best to use an external test pattern from a generator or an AVIA test DVD. There always seems to be some difference between the internal test pattern and the signal source when it comes to convergence. Make sure that you select the internal test pattern that is at a frequency higher than your inputted signal to get the most accurate convergence from the internal test pattern generator.
There are no adjustments to this board, leave the trimpots alone!
... Previous Page Next Page ...
