![](images/spacer.gif) |
Ampro 1500/2000
High Voltage (HV) Power Supply:
![](images/Ampro2000image012.gif)
Here is weak point # 2 on the Ampro 2000. The HV supply has caused more grief
and despair in Ampro owners when it fails unexpectedly. While they don’t fail
very often, they are somewhat hard to find and are very expensive from Spellman,
the manufacturer. There are a number of styles of Spellman HV supplies, some of
which are interchangeable with each other, most are not. The HV output changed
from model to model, as did the power input connections. The model number of
each supply is found on the silver sticker pictured above. Common model numbers
are X 1685, X 2102 and X 2394. Each HV supply has one or two internal fuses that
can be accessed by removing the covers to the power supply. If the internal fuse
blows again after replacement, then there’s a problem within the supply. I have
had limited success repairing HV supply faults not located in the sealed
silicone section of the HV supplies.
Earlier HV blocks had three independent HV output connections that went to
the tubes, and contained the focus controls right in the HV block. Later HV
power supplies used a separate focus and HV distribution block, undoubtedly to
take some of the heat generated within the supply away from the HV components.
