Ampro 1500/2000
RGB Board:
![](images/Ampro2000image005.gif)
The above picture is the analog RGB input board for the Ampro projectors. Again,
there are several versions of this board, not all of which are compatible with
others. The only adjustments on this board are the 5 pots as labelled above. The
Ampro manual does a good job telling how to set these pots up. Too much pressure
on the pots, and they will shear off.
Not labelled on the above picture are the 3-2 pin video output connectors on the
back of the board that feed the video signals to each CRT socket. Note that
these connectors are direction specific. If you install the connectors
backwards, you’ll get no video image on that particular tube.
Also not labelled above are the three small RGB level trimpots on at each BNC
connector. The default setting on these multi turn trimpots is fully clockwise.
These are 10 turn pots, and they will audibly click when the max CW point is
reached. I've received many surplus units in with these controls turned way
down, and the result is a weak color when an RGB signal is being used. These
controls can be used to gain balance all three colors when an RGB signal is
used.
Note that the stock RGB card uses an RGB signal with a combined H and V sync
connector labelled ‘s’ for the sync. If your RGB source has separate H and V
cables, then use a BNC ‘T’ connector to combine the two leads into one.
