    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Series
      >> Introduction
      >> Layout and Setup Tips
      >> Mechanical Setup Procedure
      >> PG Models and Production Run Dates
      >> PC Control Cable Pinout & Software
      >> Manuals / Downloads
 (Page 7)
Page: 1 2 3 4 5 6 7 8 9
Video Output Board
The below images show the PG series of video output boards. The PG + and PG Xtra used slightly different looking boards with the video output chips being located on the CRT sockets instead of on the board itself.
Again, there are a number of trimpots located on the video output board, and it’s very tempting to tweak and turn these pots to ‘make the color look better’. Trust me, don’t do it. Unless you have a colorimeter and an oscilloscope, don’t touch these controls. The NEC service manual is very poorly written with regards to aligning these pots, and the adjustments are tricky.
This board is located under the metal shield that has the fan on it near the back of the set. The later PG Xtras did not have a large heat sink on this board as the video output chips were on the CRT sockets. Note that the leads connecting this board to the CRT socket are VERY tight, and easily pull out of the PC board sockets when this board is disturbed. That can cause a dead tube or one with weak light output. If you dare work on this board and then have tubes that won’t light, check the wiring to this video output board.
I have not taken pictures of the video driver board or the video input board. Again, these have no serviceable parts on them, and generally do not fail. The video/s-video input board is located under the video board shield, and is located closest to the back of the set. The 6PG series sets did not include this board, it was an option. Therefore, even though the video and S- video jacks are on the front of the 6 PG units, chances are they are dead, as they will not work unless the video board is installed.
... Previous Page
Next Page ...
