    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Series
      >> Introduction
      >> Layout and Setup Tips
      >> Mechanical Setup Procedure
      >> PG Models and Production Run Dates
      >> PC Control Cable Pinout & Software
      >> Manuals / Downloads
 (Page 4)
Page: 1 2 3 4 5 6 7 8 9
Convergence board
The C board will fail on occasion, usually due to the high heat generated by this board.
A failure on this board is usually indicated by an ‘F8’ error code on the back LED display. The set will usually power up for a few seconds, then will shut down and the F8 error code will appear on the back LED. A quick test to determine whether this board is bad is to pull off the power connector from the C board. If the C board is bad, the set will now continue to run without shutting down, however you will lose all control of the convergence functions.
The 6 yoke connectors go to the convergence yokes. The connectors that are red/blue controls the convergence in a L-R direction (horizontal) and the yellow/brown wires are for the vertical convergence.
Note that there are two different types of convergence boards, and the yoke wire orientations are different between the various PG sets. If you remove this board, mark all 6 connectors so you know how they plug back in. If you get massive amounts of pincushion so that the sides or the top and bottom are way out of whack, pull the appropriate yoke wires out and reverse them 180 degrees. You’ve got them backwards. The orientation of these connectors will change depending on whether you are floor or ceiling mounting.
... Previous Page
Next Page ...
