    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Series
      >> Introduction
      >> Layout and Setup Tips
      >> Mechanical Setup Procedure
      >> PG Models and Production Run Dates
      >> PC Control Cable Pinout & Software
      >> Manuals / Downloads
 (Page 6)
Page: 1 2 3 4 5 6 7 8 9
System boards
I am lumping the system, wave and control boards together as they all work together and have no user adjustments on them. These boards all fit in the shielded card cage. The PG model had two system type boards, the PG + and Xtras had all three. The boards between the models changed, so you can’t mix and match these boards. Even the 6 and 9 PG models use different boards, and some problems will result if you don’t use the right board or software revisions.
Again, there are no user adjustments on these boards. The most common failure of these boards is caused by a bad system board which usually causes loss of sync at certain resolutions. Usually either a video or S-video signal will work (480i) and/or 480p with an RGB input will work, but all other resolutions will not lock properly. On occasion I can repair these boards if this occurs, often the system board will need replacement. Fortunately, these boards do not fail often.
Not pictured is a similar looking point convergence board which also fits into the shielded card cage. This board provides 100 points of convergence per color that is used to fine tune the image. The point board came stock with the 9PG series of sets, it was optional with the 6 PG series.
... Previous Page
Next Page ...
