![](images/spacer.gif) |
Electrohome ECP Series
Waveform board
![](images/ECPimage010.jpg)
As the title implies, the convergence waveform board generates the waveforms
for the convergence board. I will be posted a separate tech tips section that
describes how to tweak the trimpots on the front of this board, again under
normal circumstances it’s not required to turn these pots. The pincushion board
is stacked as a daughterboard on the main board as shown above on some versions
of this board. Some do not have this daughterboard.. It’s common for the module
contacts to go intermittent. The remedy is simple, take off the daughterboard
and insert it back onto the motherboard several times. This cleans the contacts,
and you’re good to go for another few years.
ACON board
This board was an option on all models that ended in ‘00’, and was standard
equipment on the models ending in ‘01’. Of course, some ACON cameras were added
after the fact and some were removed. The ACON consists of three parts: The PC
board installed into the rear of the set, the camera on the front, and the 25
pin cable that plugs into the camera and snakes to the motherboard.
The ACON camera assists in the setup and convergence of the unit. When the
ACON is installed and working properly, it will align the R and B tubes to the
green grid that you need to set up manually. It’s fun to watch, but you can
always do a better job manually. When the ACON is installed, the ACON option
will come up in the convergence menu. Select it, and the ACON will do it’s job.
The ACON PC board is fairly reliable, but the mechanical servo controlled
camera had it’s issues. Most often, the camera got hit physically and sustained
damage to the servos. Over time, the optics of the camera became dirty, and
would show error messages. The optics are cheap and dirty in these ACON units,
and it’s not difficult to pull the camera open to clean them. Note that the ACON
must be operated in complete darkness for the best results, any ambient light
will throw the camera off.
