Electrohome ECP Series
Looking under the back cover of the ECP projector, all models used the same
board layout as shown below.
![](images/ECPimage001.jpg)
Upon holding the power button down for 2 seconds, the set powers up and the
green power supply lights should all come on, indicating that all power supply
voltages are present. The red lights on the H and V boards may come on
momentarily, but should go out after the set goes through a number of self
checks. Once the self checks test OK, the high voltage will crackle up, and the
tubes should light up if an input signal is present.
Starting from the left referring to the above image, the blank panel only
houses an 1/8” mini jack so that a wired service remote may access the
projector. This is useful for doing close screen convergence, when the projector
is used in a rear projection mode or if the projector is far away from the
screen.
The first PC board with the green lights on it is the vertical output board.
It provides the vertical sync and output, and has the master height and
linearity controls on it. An H and V scan fail light are also on this board.
The second board is the horizontal processor. This board has the horizontal
driver and sync sections of the set on it, and those signals then drive the H
deflection boards that are located under each tube.
The third board is the CPU board that has the main microprocessor, the Dallas
chip and the master reset button on it.
The fourth board is the waveform board that generates the convergence
waveforms for the convergence board on it.
The 5th slot is usually empty, reserved for the ACON or automatic convergence
board. If the ECP model is designated as an ‘01’, ie. 4101, 3501, etc, then the
set originally came from Electrohome with the ACON board and camera installed.
Some people remove the ACON hardware, it’s easy to install onto sets that did
not come stock from the factory with it.
The sixth board is the main convergence board. This board controls the
convergence parameters for all three tubes.
The seventh slot is the video gain board. This controls the amount of R G and
B signals going to each video output board located on the back of each CRT.
The eighth slot (shown here as a blank) is designated as Slot 0, the first
video input board. Each ECP has the ability to accept two video input boards
that came in a number of configurations, either video, S-video or RGB. Most
boards were dual input , so with two input boards, you had available a total of
4 video inputs, eliminating the need for an external video switcher. Neat,
huh?!?
The ninth slot was the second video input card, designated as SLOT 1. When
pressing the remote input selection, you select which slot you want to use, then
which input on that particular slot. So ‘Source’ ‘0’,’1’ selected the first
input on slot 0. ‘Source’ ‘1’,’2’ would select input 2 on slot 1. THE picture
above shows a common dual RGB input board. Input 1 is a unique Electrohome 10
pin connector, and the matching plug is hard to find. Input 2 is a 5 BNC
standard RGB input that accepts RGsB, RGBS or RGBHV signals.
