    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome ECP Series
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 5)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13
Located below each CRT are the H deflection/convergence output board. Again, all three boards are identical, and you can swap these boards between tubes. Note however that a failure on one of these tubes usually shuts down the HV, and the H error light will light up on the back. Swapping the boards within the set will do nothing, you’d need to get a working deflection board and swap out these boards one at a time.
Horizontal Deflection board
The above picture shows the two main adjustments on the H deflection board. The master width pot works ONLY on the green board, the R and B width pots have no effect. This is normal. Set the width on the keypad to ‘5’, and set this width pot so that a good amount of phosphor area is used. That allows some give and take adjustments via the width control on the keypad when changing resolutions.
The V size control works independently for each color. The idea of these controls is to match the height of all three CRT’s without making massive use of convergence controls to shift the height of each color. This reduces convergence drift.
The convergence and H/V yoke plugs connect at the back edge of each deflection board. The H and V connectors pull out and reverse 180 degrees. This orients the image correctly whether floor or ceiling mounting. Both connectors need to be flipped on each H deflection board to properly orient the scanning of each tube.
... Previous Page
Next Page ...
