    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome ECP Series
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 11)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13
Video Gain board
This is a late model video gain board. The only adjustments on this board are the three gray trimpots as shown above, and they are adjusted as follows:
Input a standard video signal so that you have an image on the screen. Turn the brightness control on the keypad to 10, set the contrast to 0. Look into each tube. If these pots are set correctly, all you will see is a blank screen. If the controls are misadjusted, you will see either a slight image or a slight negative of the image you’re feeding to the projector. These pots are 10 turn pots, and you’ll see a ‘null’ as the image goes from a negative one to a positive. Each pot/color should be set to that null position. Then return the brightness and contrast to 5 or whatever level you use.
Video Input boards
The various video input boards are very reliable and fail rarely on the ECP sets. The most common problem is a 5 volt regulator right on the edge of the older video/S-video boards, and it can catch the edge of the case when pulling the board out or when putting it in. The RGB inputs boards don’t really fail from my experience.
... Previous Page
Next Page ...
