    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Bleeding CRT Tubes
 (Page 8)
Page: 1 2 3 4 5 6 7 8
The front glass on one of my CRT tubes broke because of this excessive pressure, how can I get the front glass off a tube?
This is the company that sells the stuff you need to remove the front glass of the CRT.
Dynaloy, Inc.
1535 East Naomi Street
Indianapolis, Indiana 46203
800-669-5709 or 317-788-5694
You want to order their product Dynasolve 225, it usually takes a couple days to loosen up the RTV.
Where I can get glycol that's used as a CRT coolant?
CRT coolant contains ethylene glycol and glycerine, usually in a 70/30 mixture. It can be purchased from most suppliers of consumer electronics parts like Tritronics or Andrews, or even MCM.
Ethylene glycol is not itself corrosive at all, but is a very good solvent. It absorbs moisture from the air and forms a corrosive mixture eventually doing serious damage to a circuit board. It is not sufficient to simply wipe it off. It needs to be washed off. Use denatured alcohol or isopropanol. A light detergent and water can work as well, but takes longer. If you had a leak or a break, make sure to check everywhere in the projector. You don't want coolant on any boards!
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Back to Page 1
