    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Tube Fungus Removal
 (Page 2)
Page: 1 2 3 4 5 6 7 8 9
How do I fix a tube that has fungus?
You have two choices:  You can fix it yourself or you can get VDC to do it for you for a reasonable fee. Contact them for exact pricing/details.
If you decide you want to do this yourself, read on!
We need to clean the existing fungus off and re-spray the aluminum to prevent it reoccurring. Doing so requires that the glass in front of the coolant chamber be removed, cleaned, re-sealed, and re-filled with coolant.
Note: The following instructions deal with air-coupled tubes that have flat glass sealed directly to the front of the coolant chambers. The curved glass in front of the coolant chamber (called the c-element) of liquid coupled tubes is (usually) easily removed with only a few screws, therefore some of the steps in the procedure outlined below would actually be considerably simpler for LC tubes.
Update: Here's a shorter way recommended by forum member 'jowi' 'to fix the fungus problem that can be used in some circumstances that doesn't involved removing and resealing the glass plate:
"Take the tube out, unscrew both fill screws on top, keep it upside down, put a plastic syringe (no needle!), which will fit on one of the screw holes nicely, and simply pump the glycol out through the other hole, not removing the syringe, just pump. In like 30 seconds your tube is empty.
Collect it using a coffee filter and a glass. Then take some ammonia (or CLR), fill the tube for 30% with it, and shake it baby! The inside of the tube is now clean. Pump out the cleaner, fill the tube with some water a couple of times so the cleaner is gone, and then refill it with your glycol. A bit of water in the glycol is no problem at all. So don't worry about it.
Finished! No need for removing and cutting glass and remount the glass etc. A tube is removed, cleaned and refitted within 30 minutes...
Note: If the inside materials of the tube are deteriorating, simply flushing won't treat it. But in a lot of cases the 'fungus' is just caused by crystallization of the glycol itself, e.g. if the tubes haven't been used in a while or due to some (bacterial/chemical?) impurities. The crystallization then settles on the glass. In those cases, the simple flushing method will be sufficient. As long as the tube is being used regularly, the glycol is heated up again and again and will convect in the tube, thereby doing what it's supposed to do (cooling the phosphor) and impurities or crystallization will not have the chance to settle."
If you're still interested in ensuring 100% that fungus problem won't re-appear, read on for the full procedure with pictures!
Step 1:
Pull the tube out. You may leave the HV lead connected, but you may find it easier to disconnect it entirely. (Note: There is another advanced procedure on this website that details how to remove the HV lead on this website if you decide to follow this route).
... Previous Page
Next Page ...
