    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Ampro 3600/4600
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 1)
Page: 1 2 3 4 5
The layout of all Ampro projectors is very similar, from the older 2000 to the latest 4600. There are some board changes between models obviously, but if you’ve seen one Ampro, you’ve got a good idea of how most of them are laid out internally. The below view shows the main chassis view of a late model 3600. The 3400 and 4300/4600 sets are virtually identical.
There are virtually no user serviceable parts on these boards. The later model Ampros did not have nearly as many trimpots on them as earlier sets.
All boards in the back of the set mount to the back of the chassis with two small Philips screws. Take out the screws and the boards pull right out. (remember to UNPLUG the set before removing boards, or serious damage can occur).
Internal boards (going from left to right)
CPU board: This board is quite reliable and has no user serviceable parts on it. The only part that fails occasionally on this board is the 3.6 volt lithium battery which is rated at about 5 years life, but typically lasts 10 years. Replace the battery or send the board in for service if it measures under 3.5 volts. When this battery dies, the set will still work, but the convergence memory will not hold when the set is unplugged. Also, the hour meter will usually glitch and indicated hundreds of thousands of days of use, as of this writing I have not found a way to reset the hour or CRT meter if this happens.
RGB input board: All Ampro sets come stock with one RGB input board. All RGB signal processing is on this board as is the test pattern generator. Generally this board is reliable. With the amount of SMT parts on this board, servicing by the end user is not recommended.
Optional RGB/quad decoder boards: All Ampros come with the option to add a secondary RGB input board and/or a quad decoder (video/Svideo) board. Some sets didn’t come with the female connectors installed on the motherboard, most have one spare connector installed on the chassis. The secondary RGB input boards have a lot less components installed than the main RGB board, and are hard to find. The video/s-video boards are readily available.
H Supply board: This board supplies signals and voltages to the H drive and output board. I have never had one of these fail.
V deflection board: This is the vertical oscillator and output board. There are two trimpots that adjust the master R and B height as compared to the green tube. These trimpots are accessed through the back of the set with a small screwdriver. To adjust these: Turn off the registration (55, code) so that the convergence has no effect on the raster. Put up the test grid crosshatch, and set the height of the R and B tubes to be the same as the green. This will minimize the amount of convergence required to adjust height parameters and will cause the convergence output section to run cooler. Note that the static shift of the R and B tubes are accessed through the remote control with a ’40, code’ and ’41, code’.
H Drive board: This board sends signals to the H output board. Failure of this board is rare.
H output board: This board drives the H yokes on each tube. This board can fail, as high currents and voltages run through this board. There is a master H width trimpot on this board as well that does not normally require adjustments, but under certain resolutions you might find that you do not have enough width to make good use of the raster. If that’s the case, CAREFULLY adjust this trimpot so that you use a good amount of the tube face without running off the edge of the tube.
HV power supply: The later HV power supplies were quite reliable, as the HV splitter section was removed from the supply itself, and thus the HV supply ran cooler than the older models. There are a number of HV supply models, some of which are interchangeable. Take a look at the part number, and we usually only refer to the last numbers in the model number as the supply type, ie. the X 1914, X 2102 or X 2394. This sticker is on the HV supply that is facing the green CRT socket. If you have an HVPS with a different model number but with the same connectors, chances are it will work. If the connectors are different, I would not try swapping them out.
LV power supply: The LV supply is held to the frame by two screws on each side of the top metal plate of the supply itself. Two screws face the RGB board, two face the Horizontal Supply board. Loosen these screws (again, make sure the power is disconnected from the set), and the LV power supply pulls right out. There are no trimpots that should be adjusted on the LV power supply.
There are fuses under the fuse cover, accessible without removing the LVPS. If you change a fuse and it blows again, you have a short somewhere in the set that is causing the fuse to blow. The problem is, the Ampro Pc boards have interlocks that do not allow the set to turn on when a board is removed (with the exception of the convergence and focus output boards). If there is a short on a PC board somewhere, sending boards in for testing or swapping out a defective board are about the only ways to check for internal shorts without diving into the chassis with a scope or meter.
Next Page ...
