MUX-HD V1 color question
Posted: Sun Aug 17, 2014 2:31 am    Post subject: MUX-HD V1 color question
Found one of these when I was cleaning up over here so I decided to try it with a Samsung DTB-H260F into my RPTV at 1080i.
For the most part the picture is Black and White BUT- RED comes through. Making everything look like one of those black and white photos with the roses colored in. Kinda cool but it made for an interesting episode of CSI Shocked
I have the remote but not the manual. IS there a way to manually change the color space on this?
Signal chain is:
H260F--HDMI.cable---->MUX-HD---DVI.to.DVI.cable--->TV
Posted: Sun Aug 17, 2014 6:28 am    Post subject:
OK just did a little testing....
The MUX-HD works OK with the SONY S550 Bluray player regardless of selected color space. 4:2:2, 4:4:4, RGB 16-235, & RGB 0-255
Wonder why the Samsung box won't display properly? I previously had it running into an HDFury1 to an IFB-12 card in the 1270 switch and out to the SONY D50. Color was perfect. Hmmmm????????
moome
Posted: Sun Aug 17, 2014 3:42 pm    Post subject:
hi, try to press remote C or D.
mux_hd_v13.pdf
 Filename:  mux_hd_v13.pdf
 Filesize:  326.53 KB
 Downloaded:  571 Time(s)
Posted: Mon Aug 18, 2014 3:52 am    Post subject:
Hi Moome,
Pressing C or D did not fix the color.
moome
Posted: Mon Aug 18, 2014 1:13 pm    Post subject:
Hi Moome,
oh, yes, C & D are to select output mode.
MUX-HD can not manual select the input color space.
the mux-hd may get incorrect Avi info, so MUX-HD can not know which color space to select.
then you will need MUX-FHD.
Best Regards
