    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Troubleshooting Tips > Barco
Back to Troubleshooting Tips Index
Select a topic:
High Voltage/Power Supply Issues: Dead Set - No Power at all
There are two basic ‘dead set’ faults. One is no power at all to the set, the red standby light on the back of the projector is completely off and there are no processor lights on on the controller board. This is due to a bad AC input board, or the standby power supply has gone dead, or in rare cases, there’s a short in the set that is shutting down the standby power supply.
The easy fix is a blown fuse on the AC input board. There are two fuses located on the AC input board. If the fuses are original Barcos, they are sand filled, and a meter must be used to measure if the fuses are intact or not. In fact, it’s a good idea to test the fuses for continuity anyways as fuses like this can blow right at the end caps, and it looks like the fuse is OK, yet it has no continuity.
Once in a while one of the fuse holders on the AC input board goes bad and there’s a poor contact made between the fuse and the fuse holder. Usually the fuse holder at one end will become discolored, indicating the bad fuse holder.
There is a main fuse on the SMPS as well. Usually if this fuse is blown, there’s some other kind of problem on the SMPS, but there’s no harm in trying a new fuse (3 amp). If the new fuse blows instantly, there’s no point to installing a second fuse, pull the power supply and send it in for repair.
The standby power supply that powers the controller module and the IR sensors for the remote control is located on the daughter board of the SMPS. There’s a 125mA fuse on this board, and again, it’s a good idea to measure this with a continuity tester to confirm it’s bad. These fuses are hard to find, and will not be stocked at Radio Shack. If the fuse blows a second time, again that indicates problems in the SMPS somewhere.
The standby power supply feeds the IR sensor at the back of the set, the one on the front on the convergence board, the wired keypad, and the controller board. If all fuses check OK but the rear red LED is off, it’s rare but possible that either IR or the controller board has developed a short, thus shorting out the power supply. Try pulling out the convergence board and see if the set will power back up. If not, try pulling the rear IR sensor plug from the motherboard and see if the set powers up. Similarly, disconnect the wired keypad and see if the set will power up with the wireless remote.
If none of these steps cause the rear red LED to light up when the set is off, then it’s safe to assume that the SMPS is bad.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Next Page ...
