![](images/spacer.gif) |
High Voltage/Power Supply Issues: Dead Set - Rear Red LED is on
The other scenario with a dead set is
that the standby supply is on and thus
the rear LED on the back of the set is
red, however when the power button is
pushed, the set will not turn on, or
will turn on partially.
If the set will not come out of the standby mode, most likely the SMPS has a
fault on it, and the main power supply section is not turning on. As the power
supply in the Barco is pushed the hardest, failure in this module is relatively
common. I do a number of mods to the power supply to make it more reliable.
It is however possible for a shorted EHT board to shut down the SMPS. Pull
out the EHT board and try to power up the set. If the set turns on, the fans
spin but has no picture, then the EHT board is shorted and should be sent in for
repairs.
Other boards in the set may also load down the power supply so that it does
not turn on. It is possible for almost any board in the set to have a dead short
on it. Pull out each board one at a time and try to get the set to turn on. You
won’t get a picture, but if you remove the shorted board, the fans should at
least spin. Send that board in for repair.
Did you find this information useful? Please consider making a
donation to help defray the cost of managing and hosting future
articles, tips, and documents. |
Or
purchase
from
Amazon.com
and a small percentage automatically
goes to support this site at no extra cost to you! Visit their
Blu-ray and
4K UHD
stores for sales.
Want to show off your
home theater? See our
Blu-ray Release List & Must-Have Titles. |
