![](images/spacer.gif) |
High Voltage/Power Supply Issues: No Picture, HV Problems
Many times a Barco set will display
no picture due to loss of the high
voltage. This can be due to:
- Shorted/imploded CRT
- Bad HV splitter
- Bad HV quadrupler
- Bad EHT board
- Bad SMPS
Check to see if the set is in HV shutdown mode by looking at the red LED on
the EHT board. If this LED is on, then most likely the HV splitter, quadrupler
or the EHT board itself is bad. There’s no way to accurately check these
components with a meter, you need to substitute parts or check your components
by installing them in a working set.
Much more rare are shorted tubes. A tube that has lost its vacuum acts like a
dead short to the HV section. You can completely disconnect a tube from the set
by disconnecting the tube’s red HV lead from the HV splitter and then also by
pulling the CRT socket from the back of the tube. Beware, there are high
voltages here! Once you disconnect the shorted tube from the set, the remaining
two tubes should work normally.
If the red EHT light is not on, the scan fail light is not on, but you still
don’t have a picture, it’s still possible to have no high voltage. It’s possible
that the EHT board has gone bad (check the fuse on the EHT board, that could be
one possibility) or dead, or the SMPS may not be sending power to the EHT board.
It’s also possible that the H shift board has gone bad. There’s a pulse that
comes from that board, and if it’s missing, there will be no image displayed.
Did you find this information useful? Please consider making a
donation to help defray the cost of managing and hosting future
articles, tips, and documents. |
Or
purchase
from
Amazon.com
and a small percentage automatically
goes to support this site at no extra cost to you! Visit their
Blu-ray and
4K UHD
stores for sales.
Want to show off your
home theater? See our
Blu-ray Release List & Must-Have Titles. |
