Sony G70
Layout and Setup Tips
(Page 7)
Page:
1 2
3 4
5 6
7 |
Removing tubes:
Swapping out tubes in the G70 is quite easy. Here’s how to remove the tube
assembly. (whether you choose to remove the tube with the yokes and other
hardware on it, or if you choose to slide the hardware off the neck of the tube
while pulling it out of the set is up to you).
Remove the two brass screws that hole the tube of the tube in place, and
remove the center screw of the tube that has the black ground wire screwed under
it as shown. Loosen but don’t remove the long black shafts that hold the bottom
of the tube in place.
![](images/SonyG70image13.jpg)
There is a small slide lever under each tube assembly as shown below that
locks the bottom of the tube in place. Slide this lever towards the lens and
push it sideways to lock it out of the way:
![](images/SonyG70image14.jpg)
Disconnect the red HV lead from the HV splitter by pulling back the gray
rubber boot covering the lead, then push down hard on the red HV lead going into
the block, rotate 90 degrees CCW, and the HV lead should slide right out of the
HV splitter. If the red lead doesn’t come loose, try pushing down hard on the
lead and twisting again. There are two tiny metal tabs at the tip of each HV
lead that need to unlock from the splitter block before the lead will come out.
Forcing the lead will most likely snap the metal tip off in the block, and
that’s then very difficult to remove from the block:
The tube will then slide out of the front of the set. Here’s a picture of the
removed tube with all of the yokes and hardware still in place:
Did you find this information useful? Please consider making a
donation to help defray the cost of managing and hosting future
articles, tips, and documents. |
Or
purchase
from
Amazon.com
and a small percentage automatically
goes to support this site at no extra cost to you! Visit their
Blu-ray and
4K UHD
stores for sales.
Want to show off your
home theater? See our
Blu-ray Release List & Must-Have Titles. |
