Sony G70
Layout and Setup Tips
(Page 2)
Page:
1 2
3 4
5 6
7 |
Front of the set:
Looking at the front of the set with the lenses removed (one screw in each
corner of each lens as shown below):
![](images/SonyG70image03.jpg)
We see that each tube has a concave C lens as with all LC projectors. The red
and the green lenses are tinted stock from the factory for more accurate color
reproduction, the blue C lens is clear. DO NOT remove any of the screws
surrounding the C lens, there’s a pint of cooling fluid behind each C element,
and if that fluid spills into the set, you can pretty much write the projector
off.
Here’s a picture of the screws that you need to take off to access the tubes
themselves. (two of 4 are shown):
![](images/SonyG70image04.jpg)
