Sony G70
Layout and Setup Tips
(Page 1)
Page:
1 2
3 4
5 6
7 |
Here is an overview of the modules and components of the Sony G70 projector.
Unlike a bunch of other sets on the site here, there are literally no internal
adjustments that are required on this model, so people that like playing with
controls that they shouldn’t be will be somewhat disappointed in this set. Let
me be perfectly clear: Any trimpots found on the boards in this projector
SHOULD NOT BE TOUCHED. I have yet to see a projector that needs tweaking of
the internal controls, all installation and alignment adjustments are done via
the projector menus and the controls on the keypad or the remote.
Under the top cover:
The top cover is relatively easy to remove: Undo the two screws over the lens
cover, lift the lens cover up, rotate the two large flat head screws 90 degrees,
and the whole top cover will lift up and off of the set. (the two large flat
head screws do not remove from the case).
Removing the lens cover off the front of the set is easy once you find the
release tabs of the cover shown here (behind my finger):
![](images/SonyG70image01.jpg)
Pull the two metal tabs towards the outside of the case, and the front cover
will hinge forward and come off the set, exposing the lenses.
Under the top cover are the yoke connectors and switch that allow you to flip
the orientation of the image. The three blue/red wire connectors flip the image
horizontally, the small switch flips all three images in the vertical direction.
There are two positions for the H yoke connectors, the connectors must be
flipped and inserted into the other jack to flip the image:
![](images/SonyG70image02.jpg)
