![](images/spacer.gif) |
Sony 125x/127x
Layout and Setup Tips
(Page 8)
Page: 1 2
3 4
5 6
7 8
9 |
![](images/Sony1272image010.jpg)
Under the shield between the R and B tubes are the CPU boards. Actual failure
of these boards again is rare, but bad module or IC socket connections can
result in erratic operation or convergence memory failure. Before you remove
these boards, make sure the AC power to the set has been disconnected for 10
minutes, as the standby power supply is always present on these CPU boards.
Removing these boards without unplugging the set can zap these boards.
