![](images/navbasebg.jpg) |
![](images/spacer.gif) |
CRT
Projector Specifications > Electrohome
Select a manufacturer:
Model |
CRT Size/
LC |
CRT
Type |
Chassis
Controls |
Peak
Lumens |
Contrast
x:1 |
HScan (kHz) |
VScan
(Hz) |
Band
width
(Mhz) |
Screen
Size
(inches) |
Max
Resolution |
HDTV
Inputs |
IR
Remote |
Point
Convergence |
EM
Focus |
New
Price
(USD) |
EDP 57 |
7" |
Digital |
725 |
15,000 |
15-33 |
45-90 |
30 |
60-250+ |
480p |
Y |
V/R |
N |
3195 |
EDP 58 |
7" |
Digital |
725 |
15,000 |
15-33 |
45-90 |
30 |
60-250+ |
480p |
Y |
V/R |
N |
3195 |
CadCam |
7" |
SD187 |
Digital |
725 |
15,000 |
30-71 |
45-100 |
60 |
60-250+ |
1024x768 |
Y |
V/R |
N |
ECP 1000 |
7" |
SD187 |
Digital |
725 |
15,000 |
15-33 |
60 |
30 |
60-250+ |
480p |
Y |
R |
N |
ECP 2000 |
7" |
SD136 |
Digital |
725 |
15,000 |
15-36 |
42-100 |
30 |
60-250+ |
540p |
Y |
V/R |
N |
9995 |
ECP 2100 |
7" |
SD187 |
Digital |
600 |
15,000 |
15-38 |
42-100 |
30 |
60-250+ |
540p |
Y |
V/R |
N |
9995 |
ECP 2500 |
7" |
07MS |
Digital |
725 |
15,000 |
15-50 |
45-120 |
40 |
60-250+ |
1024x768p |
Y |
V/R |
Y |
N |
9995 |
ECP2500 Plus |
7" |
07MS |
Digital |
725 |
15,000 |
15-50 |
45-120 |
50 |
60-250+ |
1024x768p |
Y |
V/S/R |
Y |
N |
9995 |
ECP 3000 |
7" |
SD187 |
Digital |
600 |
15,000 |
15-55 |
45-120 |
50 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
14400 |
ECP 3100/01 |
7" |
SD187 |
Digital |
600 |
15,000 |
15-55 |
45-120 |
50 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
12995 |
ECP 3500/01 |
7" |
07MS |
Digital |
725 |
15,000 |
15-62 |
45-120 |
60 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
11995 |
ECP 3500 Plus |
7" |
07MS |
Digital |
725 |
15,000 |
15-72 |
45-120 |
60 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
11995 |
ECP 4000 |
7" |
SD187 |
Digital |
600 |
15,000 |
15-80 |
45-120 |
65 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
22400 |
ECP 4100 |
7" |
SD187 |
Digital |
600 |
15,000 |
15-80 |
45-120 |
65 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
18995 |
ECP 4500/01 |
7" |
07MS |
Digital |
725 |
15,000 |
15-90 |
45-120 |
70 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
16995 |
ECP 4500 Plus |
7" |
07MS |
Digital |
725 |
15,000 |
15-90 |
45-120 |
70 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
15995 |
ECP Graphics |
7" |
SD187 |
Digital |
600 |
15,000 |
15-80 |
45-150 |
70 |
60-250+ |
1280x1024p |
Y |
V/S/R |
Y |
N |
14400 |
Marquee 6500 |
8" |
180DMB22 |
Digital |
900 |
20,000 |
15-80 |
38-108 |
70 |
57-250+ |
1600x1200p |
Y |
V/R |
Y |
19995 |
Marquee 7500 |
8" |
180DMB22 |
Digital |
900 |
20,000 |
15-110 |
38-180 |
100 |
57-250+ |
1600x1200p |
Y |
V/R |
Y |
19995 |
Marquee 8000 |
8" |
180DMB22 |
Digital |
1000 |
25,000 |
15-130 |
45-150 |
100 |
57-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
22995 |
Marquee 8110 |
8" |
180DMB22 |
Digital |
1000 |
25000 |
15-110 |
38-180 |
100 |
57-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
20995 |
Marquee
8500SM |
8" |
180DMB22 |
Digital |
1000 |
25000 |
15-70 |
38-180 |
120 |
57-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
24995 |
Marquee 8500 |
8" |
180DMB22 |
Digital |
1200 |
25,000 |
15-130 |
38-180 |
100 |
57-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
22995 |
Marquee 8500LC |
8" LC |
180DMB22 |
Digital |
1200 |
28,000 |
15-130 |
38-180 |
100 |
57-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
29995 |
Marquee 9000 |
9" LC |
P19LCP09 |
Digital |
1200 |
30,000 |
15-130 |
45-150 |
120 |
67-250+ |
2500x2000p |
Y |
V/S/R |
Y |
45 |
Y |
29995 |
Marquee 9500DM |
9" LC |
P19LCP09 |
Digital |
1300 |
30,000 |
15-70 |
38-180 |
120 |
67-250+ |
1600x1200p |
Y |
V/S/R |
Y |
45 |
Y |
36995 |
Marquee 9500LC |
9" LC |
P19LCP09 |
Digital |
1300 |
30,000 |
15-130 |
38-180 |
120 |
67-250+ |
2500x2000p |
Y |
V/S/R |
Y |
45 |
Y |
31995 |
Marquee 9500HS |
9" LC |
P19LCP09 |
Digital |
1300 |
30,000 |
15-152 |
40-185 |
130+ |
67-250+ |
2500x2000p |
Y |
V/S/R |
Y |
45 |
Y |
33995 |
Marquee 9500LC Ultra |
9" LC |
P19LCP09 |
Digital |
1300 |
30,000 |
15-152 |
40-185 |
130+ |
67-250+ |
2500x2000p |
Y |
V/S/R |
Y |
45 |
Y |
33995 |
Note : A "01" suffix in any model number
signifies an ACON auto convergence system installed.
Model |
Weight in Lbs (Kg) |
Dimensions L x W x H in inches (mm) |
All ECP Series |
105 (47.7) - 131
(60) |
23.54 x 20.88 x
16.68 (598 x 530 x 424) |
Marquee
8000 Series |
145 ( 64)
32 x 28
x 17 (813 x 711 x 432) |
Marquee 8000 LC Series |
175 (79.5) |
32 x 28 x 17 (813 x
711 x 432) |
Marquee 9000 Series |
157 (71.4) |
32 x 28 x 17 (813 x
711 x 432) |
Marquee 9000 LC Series |
186 (84.5) |
32 x 28 x 17 (813 x
711 x 432) |
Glossary of Terms (click on term for in-depth information)
CRT Size/LC: Although
manufacturers measurements will vary, these measurements are the agreed
upon measurements by most enthusiasts. Actual raster
corner to corner measurements will vary based on the installation. LC is
noted for tubes that are liquid-coupled (as opposed to air-coupled).
LC'ed tubes offer greater contrast and less halo'ing. |
Chassis Controls:
Analog chassis projectors use manual "pots" for convergence, image
sizing, shift, etc. With the newer digital convergence feature,
convergence is done from the control panel or infrared remote control.
This gives you the ability to stand at the screen and more accurately
set up the focus and alignment of the CRT's. Digital convergence units
also may have memories for different inputs and aspect ratios. These
can then be changed with the push of a button on the remote. |
Peak Lumens: Lumens
relate to the amount of energy (light) that's coming from the CRT. It
describes the potential of the projector, but little of the actual
brightness you will get on screen. The brightness depends on many
factors. The most important being the screen size and material as well
as ambient light conditions. |
Scan Rates and HDTV:
The ability of a projector to display HDTV depends on its scanning
capability. For example for a projector to line double standard NTSC
signals (480i at 15.75khz horizontal) from DVD, VCR or
cable/Satellite to 480p, requires 31.5 Khz of horizontal scan rate and
enough bandwidth to handle twice the picture information. HDTV at 1080i
requires a horizontal rate of 33.75 Khz and 50 Mhz bandwidth. 720p
requires a horizontal rate of 45 Khz with 50 Mhz bandwidth.
Max resolution: This is
the maximum resolution that the projector can accept (and sync to) as an
input signal. Important: While the projector
may be able accept the signal, it may not be able to fully resolve the
information on screen without overlapping of scan lines resulting in a
softening of the picture. That is, the manufacturer resolution specifications do not necessarily reflect real world resolving
capability. |
Inputs: As listed above
V = standard composite video, usually a BNC connector on projectors
(takes a $2 Radio shack connector to convert back to RCA). S = S-video
in its usual form. R = RGB in either a DB type plug or 5 separate RGBHV
BNC type connectors. C = Component video. Any values in ( ) are
available with an optional input board. |
Zone/Point Convergence:
A feature of a digital chassis where after doing a rough convergence you
can fine tune various areas of the image for a tighter alignment |
Electromagnetic Focus: A feature on newer
projectors where you not only have the ability to focus corners and
center, but additional electronic controls for fine focus of the beam
spot throughout various areas of the image producing a sharper image. |
Did you find this information useful? Please consider making a
donation to help defray the cost of managing and hosting future
articles, tips, and documents. |
Or
purchase
from
Amazon.com
and a small percentage automatically
goes to support this site at no extra cost to you! Visit their
Blu-ray and
4K UHD
stores for sales.
Want to show off your
home theater? See our
Blu-ray Release List & Must-Have Titles. |
