    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Primer
Updated: April 2006
Index:
CRT Sizes
Panasonic (MEC) 180DVB22 8" EM focusing tube
For all intents and purposes, CRT’s come in three sizes; 7, 8, and 9”.  (Some Sony 7” tubes have a useable 5.5” raster, but we’ll get to that later).
The measurement is taken from corner to corner on the front of the tube face. Different manufacturer's have been known to rate the same tube as slightly different in size however. To avoid confusion, most enthusiasts (and this site as well) always refer to tube sizes by their actual size.  For example, we consider a NEC PG to have 8" tubes, not 7" as NEC sometimes would lead you to believe as the tubes are actually the same size as in the higher end NEC XG models.  (Who would have ever thought that a manufacturer would downgrade their specs on purpose?).
The larger the tube size, the more resolution the projector tube will be able to display as the picture that is being projected onto a large screen starts from a larger tube surface.
In general, a larger tube will also produce more brightness. Something to keep in mind if you want to have an especially large screen.
Naturally, a larger tube also costs more to make, which is why 9” projectors are expensive to buy and expensive to retube.
In general, most video-only and entry-level data grade projectors are 7”. Mid grade projectors use 8” tubes and the top of the line are 9”.
... Previous Page
Next Page ...
