    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Primer
Updated: April 2006
Index:
CRT Brightness
There is no question that CRT projectors require a dim or dark room for proper viewing. While the image will look best in a pitch black room, a low level light may be on without detracting from the image.
Fluorescent lights are very bad for a video image as is sunlight or any light coming in from windows.
Neon signs such as bar signs tint an image terribly, and often a bar must relocate such a neon sign when we install a projector.
Entry-Level CRT Projector: 600-800 lumens
Intermediate Level CRT Projector: 1000-1200 lumens
High Performance CRT Projector: 1200+ lumens
In general, most CRT projectors put out a minimum of 550 lumens, which is adequate for a 7-8’ screen.
The brightest CRT projector that I know of has rated at about 1500 lumens, which was the Barco 1001, but tube failure was common on these and several other similar older Barco models. I do not believe that an average home theatre needs more than 1200 lumens.
The larger the tubes surface, the more area there is to project an image on, and in theory the slower a tube will wear out.  Naturally, the larger tubes are rated for more light output than a smaller tube, and thus a larger tube can be driven harder than a small tube. Hence, all picture tubes last about the same amount of time (i.e. 10,000 hours) if you drive them as the manufacturer intends.
However, using CRT projector with large 9" tubes (1200+ lumens) on a smaller screen size will result in your tubes wearing slower.  It's not uncommon for a 9" CRT tube to last 20,000 hours instead of the 10,000 hours you'd get out of a 7" tube on on average sized home theater screen (i.e. 8' wide as seen in the picture above).
... Previous Page
Next Page ...
