    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Building a Hushbox
 (Page 3)
Page: 1 2 3 4 5
In this photo (below) you can see the ductwork that pulls air out of the back of the hushbox.
This 6" ceiling duct leads to a 110CFM Nutone silent bathroom ceiling fan in an adjacent room that is used to suck the air out of the hushbox:
Even though the fan is in an adjacent room, rubber bungee cords are used to hang the fan from joists to ensure that it is completely silent.
I tapped into the voltage off the projector fans in order to drive a small 120VAC solid-state relay (with 3-15VDC 'coil') which automatically turns on the bathroom fan whenever the projector's powered up. The relay coil is of very high impedance so there's no extra current being drawn from the projector to switch this relay.
Another (possibly easier) option is to use a duct fan thermostat to automatically turn on the fan when the temperature reaches a predetermined level. Smarhome.com sells one here: http://www.smarthome.com/3018.html.
By remotely locating the evacuation fan, we are ensuring that the home theater remains as quiet as possible.
Note: Check the direction of venting of your projector to make sure you push or pull air correctly. Most projectors (such as the one detailed here) pull air into the unit from the front around the lenses and vent out the back, but some models do the opposite.
... Previous Page
Next Page ...
