    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Building a Hushbox
 (Page 1)
Page: 1 2 3 4 5
The following procedure was written by Kal (the webmaster).
If you’re at all concerned about the noise that a projector will add to your home theater, consider building a hushbox for your ceiling mounted projector.
Whether you require a hushbox is very much a personal preference. Some projectors are fairly quiet to begin with (ex: Sony 10xx, Barco 70x, 80x, 120x, etc.) while some others are noisy enough that pretty much everyone considers a hushbox to be a requirement (ex: Sony 1292, NEC XG).
Regardless of the noise level produced by your projector, a hushbox will only help to increase the dynamic range of the audio portion of your home theater. A good thing all around. If you’ve spent a considerable amount of money on the audio side of your home theater, you’ve probably already realized that a hushbox is more or less a requirement to maintain that level of audio quality.
The author of this procedure (Kal the webmaster) does not recommend fan mods in order to reduce the noise level of a projector – doing so only creates more heat which will shorten the life of your projector. You’re best to build a hushbox and vent it properly to keep the electronics cool.
Below are instructions for building an effective, inexpensive solution that will not only quiet your projector, but cool it better than having no hushbox at all. A cooler projector will last longer and drift less over time.
Since every projector model is slightly different, these instructions only give general guidelines showing a successful solution instead of giving exact measurements. Use your own measurements to build a hushbox that matches your projector’s size and cooling requirements.
A big thanks to Guy Kuo of Ovation Software for some of the original ideas and principles that were employed in these instructions.
Next Page ...
