7. At this stage, update the SilenX white connector housing wiring to fit
Sony wiring by swapping the +12V and SENSE wires:
![](images/G90_fan_mod_image20.jpg)
![](images/G90_fan_mod_image21.jpg)
8. Place the three pins header inside the SilenX connector housing:
![](images/G90_fan_mod_image22.jpg)
9. Place the fan assembly back inside the G90 unit and Connect it to the Sony
internal connector this way (you must check that wires colors vs SilenX
connector housing is OK):
![](images/G90_fan_mod_image23.jpg)
10. Wrap 7cm of electrician scotch tape all around the connectors assembly:
![](images/G90_fan_mod_image24.jpg)
![](images/G90_fan_mod_image25.jpg)
11. Update the rest of the fans (3) exactly like the first one:
![](images/G90_fan_mod_image26.jpg)
The back 4 fans have now been replaced! Now on to the front fan...
