What cable do I need to connect remote to G70
69shelby
Posted: Thu Mar 27, 2008 10:16 pm    Post subject: What cable do I need to connect remote to G70
Is the cable to connect the remote (RM-PJ1000/1001) to the g70 panel a regular stereo cable or is it special? I looked in the book and it says supplied, but no part number or description? I have the pj on the floor temp and sit behind it so the remote wont function from the back, thanks.
Posted: Thu Mar 27, 2008 11:01 pm    Post subject:
Does the remote function from the front? If it does you may only need to enable the rear IR sensor, I think you can do this through the service menu.
I'm not sure what cable you'll need.
69shelby
Posted: Thu Mar 27, 2008 11:20 pm    Post subject:
The remote works, there is only 1 sensor, on the front.
jkruger
Posted: Thu Mar 27, 2008 11:30 pm    Post subject:
The cord I used was a standard headphone extension cord with male plugs on both ends
rabies_70
TV/Projector: Sony G70Q
Posted: Thu Mar 27, 2008 11:44 pm    Post subject:
Its just 2, 1/8 inch stereo plugs on a length of cable. And unless someone physically removed one of your G70's ir receivers, there are two. One in front, one in back and they need to be turned on in the service menu like Zebu said. Good luck
Ray
I am an iconoclast
69shelby
Posted: Thu Mar 27, 2008 11:50 pm    Post subject:
i got a cable to work, where is the rear sensor? I dont see it and there is no call out in the manual, thanks
rabies_70
Posted: Fri Mar 28, 2008 12:01 am    Post subject:
Right next to the power on off indicator and the error window. I think they call it out as CIRCS control or something front, rear or both if I remember correctly
Ray
I am an iconoclast
69shelby
Posted: Fri Mar 28, 2008 12:28 am    Post subject:
ok, I see it now, had the cover off and didnt see a window and the installation manual didnt show it but the setup does, Thanks.
