March 23rd-29th, 2008 What got watched on your Blu-ray?
Posted: Thu Mar 27, 2008 8:44 am    Post subject: March 23rd-29th, 2008 What got watched on your Blu-ray?
Of course, if you do not own a device that can play Blu-ray movies then you are not wanted here. Mr. Green
Posted: Thu Mar 27, 2008 11:34 am    Post subject:
Hitch (BR) my wife loves that movie.
Workout dvd's
Oceans 13(BR)
Posted: Thu Mar 27, 2008 1:37 pm    Post subject:
The Assassination of Jesse James by the Coward Robert Ford
Edward Scissorhands
Posted: Thu Mar 27, 2008 3:14 pm    Post subject:
The Simpsons Movie. "Spider Pig, Spider Pig... Does whatever a Spider Pig does..." Hilarious.
Oh, and a few new trailers I downloaded from Apple.com and moved over to the PS3. I love my PS3.
Posted: Thu Mar 27, 2008 3:32 pm    Post subject:
Interesting. Tell me more about this... you're downloading the full 1080p versions right? How do you save them? Anything special I need to know to get them on the PS3? (File format, directory location, etc).
Posted: Thu Mar 27, 2008 8:08 pm    Post subject:
Yep - mostly 1080p, sometimes the 720p files because they're smaller and still look great.
The Apple trailers are all MPEG-4-compliant AVC video and AAC audio streams wrapped in the QuickTime .mov container. You need QuickTime Pro ($30, but it's handy for other stuff, too) or another tool to extract the streams and wrap them back up in the mp4 container.
Once the .mov file is downloaded and ready to play in Movie Player, then:
1. Go to File -> Export.
2. Select "Movie to MPEG-4" from the "Export" popup.
3. In the Export Settings dialog, Video tab, make sure File Format is MP4 (and not MP4 ISMA)
4. Select "Pass through" from the Video format popup.
5. Click the Audio tab, again select "Pass through"
6. Select OK, name the file and Save.
Once it's all set, QuickTime Player will just keep those export settings as default. Throw them on a thumb drive, hard drive, or stream them, and watch some nice looking trailers!
Oh, and I used to think you had to put photo and videos in a special directory on a thumb drive or hard drive to see them at all, but found out if you press the triangle key while you're hovering over the storage device (ie, before you press the X button to select it), you have the option of listing all files. There is a naming convention for directories so it will automatically show the correct media in the folders - but I don't remember what the names are.
Rdean
Posted: Thu Mar 27, 2008 8:29 pm    Post subject:
There may be a free alternative, although I must admit I have not tried this yet. I found this on the other site and I'm just passing it along.
If you install QuickTime Alternative and the select the browser plugin then when you click on an HD trailer link it will give you the option to download it instead of watching it.
http://www.free-codecs.com/download/QuickTime_Alternative.htm
Being .MOV files though they won't play without a bit of modding
Enter YAMB. http://yamb.unite-video.com/
Load the .MOV file and in a few seconds you can change the container to a PS3 compatible .MP4 files leaving the original video (H.264) and audio (AAC) untouched.
Posted: Thu Mar 27, 2008 9:26 pm    Post subject:
Thanks guys! I'm trying out the QT alternative right now...
EDIT: Hmmm... This "QT Alternative" doesn't want to be installed when the regular QT is already installed. I don't want to remove it so I'll just go wiith the pro version.
