EXT-HD Quirkiness (solved)
nautikal
Posted: Sun Mar 23, 2008 9:24 pm    Post subject: EXT-HD Quirkiness (solved)
The Setup:
I have a NEC XG 1100 being fed by a 2nd gen EXT-HD via RGBHV. My HDMI sources are a PS3 and a HD-A2, and my component source is a Motorola cable box. The two HDMI sources have their audio being routed through the EXT-HD and into my receiver via a 25ft optical cable. The cable box has audio going from the box directly into the second optical input on the receiver. I had previously been using a HD-Fury/RTC2200 setup with the same 25ft optical cable.
Audio Issues:
I hear no audio on the PS3 menus, but when I put in the game "Rock Band" I can hear the audio, but there is lots of static (my receiver says PCM during this). When I change the Rock Band options to output in Dolby Surround, I no longer hear any audio, and the receiver blinks the Dolby icon. When I use the HD-A2, I hear audio, but the quality is terrible and sounds like it's 64kbps.
The audio works fine if I go straight from the sources to the receiver, but one of the reasons I purchased the EXT-HD was so I wouldn't have to reconnect an audio and video cable every time I changed sources.
Video Issue:
The video works perfectly with all sources, except when I put in a Blu-ray disc. When I do, the projector loses sync with the box and says "unregistered signal". If I create a new signal entry, I get the same picture. DRM problem? It works fine with HD-DVDs though.
Gino
Posted: Mon Mar 24, 2008 1:34 am    Post subject:
When you put in a blu-ray disc, is it outputting 1080p24? If so, the EXT-HD will only follow the same frame rate, so you're sending 24Hz to your XG, which I doubt it can sync to.
nautikal
Posted: Mon Mar 24, 2008 1:50 am    Post subject:
No... it's always been set to 60 Hz, and when I create the signal entry it says that the vertical refresh rate is 60 Hz.
nautikal
Posted: Thu Mar 27, 2008 3:58 pm    Post subject:
So I double checked the 24Hz setting and it was set to auto, so I turned it off and it works. But it's really weird because it had worked fine with the HDFury and when I created the signal entry it still said the vertical scan rate was 60 Hz. Oh well... it works now so I can't complain Smile. Thanks Gino and Moome.
And Moome said the 25ft cable is too long for the optical transmitter. I'll blame monoprice for not carrying anything between 12ft and 25ft.
Gino
Posted: Thu Mar 27, 2008 10:31 pm    Post subject:
No worries mate Smile
