AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Fri Mar 21, 2008 3:59 pm Post subject: 2.21Gamma Delta E = 2 Baby!! |
Who needs Gamma Correction?
| Posted: Fri Mar 21, 2008 4:01 pm Post subject: |
So you're using the HCFR sensor? Did you build your own?
GEBrown
| Posted: Fri Mar 21, 2008 6:52 pm Post subject: |
Numbers and specs are nice, but what does it LOOK like?
_________________ Member of the Marquee Maniacs Club
Moose
| Posted: Fri Mar 21, 2008 7:05 pm Post subject: |
To the ignorant amoung us - what do the graphs mean?
_________________ In the real world, I am alan halvorson, King of the Wild Frontier and Swell Guy.
| Posted: Fri Mar 21, 2008 7:41 pm Post subject: |
BTW, AFryia, you COULD benefit from some gamma boost. Your color temps are right on, but your gamma is actually a bit off. 2.21 is the approximation that HCFR calculated, but you're not following it exactly. Look closely at your luminance chart. Below about 35 IRE you're below the 2.2 line, and above 35 IRE you're above it. Expand the Y axis on that chart and I think you'll see your low-IRE levels are very low. It's not terrible, to be sure, but you could bring out a bit more shadow detail if you boosted the low end a smidge.
| Posted: Fri Mar 21, 2008 7:46 pm Post subject: |
I'm so interested in the whole HCFR thing, but I haven't taken the time yet to wade through the mountain of info to read up on it. AFryia, would you be willing to write a simple one-paragraph write-up on the process with the G70? That would be great to just have a quick overview of what you're doing. Also, I know I won't ever have time to build a DIY sensor, so I'd probably go the Spyder route. So, are you using an HTPC or processor to get response that flat, or...?
AFryia
| Posted: Fri Mar 21, 2008 9:40 pm Post subject: |
| garyfritz wrote: | | 2.21 is the approximation that HCFR calculated, but you're not following it exactly. Look closely at your luminance chart. Below about 35 IRE you're below the 2.2 line, and above 35 IRE you're above it. Expand the Y axis on that chart and I think you'll see your low-IRE levels are very low. |
I was able to get up to a 2.35 gamma. The Dellta E wasn't as low or flat. The one thing I struggled with was the Bias point when the rasters just start to light up. Could be a factor of my PJ not having a G2 control, sensor, or both. So I settled for what I have. Some day I need to redo the convergence. I'll play some more at that time.
| garyfritz wrote: | | So you're using the HCFR sensor? Did you build your own |
Dave Larsen (on that other forum) made a small batch last year. I bought one of his extras. I'm impressed with it.
| GEBrown wrote: |
Numbers and specs are nice, but what does it LOOK like? |
Honestly at first while calibrating I was afraid it was going to be dimmer than what I was use to. My HTPC desktop looked a little grey not as white. But I was determined to finish so at least I'd have a reference point.
So far I love it. I have only watched one movie since but there is definately what people call more punch. I should explain that the "punch" is not that it is any brighter it is just that bright objects jump out in mixed scenes the contrast is more dynamic. I watched Rambo First Blood. Not the greatest transfer but a lot of dark scenes (the movie played out during overcast weather in a forest). Lots of detail in the pine trees and surrounding terrain.
| ecrabb wrote: |
would you be willing to write a simple one-paragraph write-up on the process with the G70? That would be great to just have a quick overview of what you're doing. |
I'm an extreme newbie on color calibration and the HFCR software. I'll try and put something together and post it. No warranty expressed or implied though.
| ecrabb wrote: |
I know I won't ever have time to build a DIY sensor, so I'd probably go the Spyder route. |
As far as the sensor, I have a SpyderII and IMO I'd use something else, the DIY-HFCR or other. With the HFCR I can get decent results down to20 IRE, below the readings are a little erratic. But that could be my PJ too.
| ecrabb wrote: |
So, are you using an HTPC or processor to get response that flat, or...? |
No, I'm not applying any color or gamma correction with the HTPC.
I use a HTPC via DVI out to IFB-DVI card. The only processing is PowerStrip for refresh and resolution.
| Posted: Fri Mar 21, 2008 9:46 pm Post subject: |
| AFryia wrote: | No, I'm not applying any color or gamma correction with the HTPC.
I use a HTPC via DVI out to IFB-DVI card. The only processing is PowerStrip for refresh and resolution. |
OK, so you they were projector adjustments only - bias and gain, etc. - no other external processing for color or gamma, then?
| AFryia wrote: | | I'm an extreme newbie on color calibration and the HFCR software. I'll try and put something together and post it. No warranty expressed or implied though. |
Excellent - just a quickie little 'here's how I did it' executive summary type thing is all I'm looking for. I'll be interested to hear what you did and how you did it.
KrisRoberts
| Posted: Fri Mar 21, 2008 11:39 pm Post subject: |
How did you position the probe?
I played with HCFR last year with both a Spyder2 and an EyeOne.
I used a tripod to hold the probe in the center of the screen, but was only able to get good results with the probe facing the projector. Several people suggested that it was better to point it at the screen, but I was never able to get that to work well. I tried making a little black tube from a painted paper towel roll to have it look through and not see its shadow, but neither probe would respond well looking at the screen.
With the probe pointing at the projector, I found the Spyder2 to be a little slow but it was consistent. The EyeOne responded quickly, but I was frustrated because it would give me one set of values one day and the next time I used it the numbers would be different without any changes to the projector.
I'm itching to take another pass at it, and would be interested in hearing how you had yours setup.
AFryia
| Posted: Fri Mar 21, 2008 11:53 pm Post subject: |
My probe sat on a tripod in the middle of the screen facing the PJ sitting ~6" off the screen.
I can read off the screen down to about 20-25 IRE. I needed to see what was going on lower than that so I face the probe toward the PJ and live with whatever the matte white screen will do to the color.
On trick I did was stretch and hold a piece of light string from my green lens to the probe to adjust the angle of the probe.
I believe the Eye-One needs an occasion recalibration of the black reference. Not sure though never used one.
_________________ My Volt Blog
| Posted: Sat Mar 22, 2008 12:32 am Post subject: |
I Agree that it would be nice for some one who has experiance using a colorometer with HFCR to make a step by step instuction set for general use.it doesnt have to be projector specific either. I have a eye 1 sensor and down loaded HCFR and am lost. I thought i was using it rigth but my readings were all over and i know it wasnt that bad. I know i was doing something wrong so i just gave up for now.
| Posted: Sat Mar 22, 2008 1:22 am Post subject: |
I've been unable to get really sensible results for Gamma with my HCFR setup.
My gamma curves, both for the XG and the 24" Sony CRT monitor are all over the shop (XG is worse though).
Am I the only one struggling with Gamma and HCFR?
AFryia (what's your name anyway? You never sign off with it..) I see you're pointing the sensor at the PJ, from your description?
SC, it's REALLY, REALLY simple. It will take you 10 minutes to get up and going once you have a sensor.
- Install hardware (usb driver for the sensor) and software (version 2). Play on a Monitor (CRT preferred) first.
- Run it, create a new file, use the internal images (called "View Images" = THIS IS IMPORTANT TO KEEP IT SIMPLE), use the XG LC/G70 cal file I uploaded here.
- Do RGB measurements by pressing "Mesure Gray Scale" (They can't spell...Measure or Grey...I forgive them, it's the only flaw )
- Fiddle with Bias and Gain on G70.
- Bask in your Calibration expertise.
- Get a Tripod and stick the sensor 300mm or so away from the screen, point at the screen and up a bit.
- Rinse and repeat for the G70.
- It's almost too easy.
Just get a sensor and a tripod, and do it.
MikeEby
| Posted: Sat Mar 22, 2008 2:13 am Post subject: |
| Mark_A_W wrote: | I've been unable to get really sensible results for Gamma with my HCFR setup.
Just get a sensor and a tripod, and do it. |
I have an old CA-1 This software looks much better. I don't suppose that sensor would work this this software. I think I know the answer....NO!
AFryia
| Posted: Sun Mar 23, 2008 5:56 pm Post subject: |
Mark,
I first started using the HCFR DVD and got O.K results. I now run closed loop with the HTPC running the software and reading the sensor. It's a one button fully automatic mode.
Again thanks for the NEC-XG calibration file. I have more confidence in my readings now, and the results show.
Anthony
kal Forum Administrator
| Posted: Mon Mar 31, 2008 2:55 pm Post subject: |
FWIW, I've been able to get my Spyder2 to work just fine down to 10IRE producing very consistent results I set the read time to 1000ms. I use the default 300ms when taking readings from 20-100 but then increase to 1000ms when taking final readings just to see where the 10IRE ended up. It might even be able to do 5IRE (haven't tried) if I increase it to 2000 or 3000.
Some questions:
So what is the target gamma on CRT projectors? I hear 2.2, but also read that 2.5 is the right thing when I start searching around in really old AVS forum archives. What is the right target?
What is delta E anyway? in this screenshot below, a Delta E value is taken at each of the 10 IRE steps... what does it represent?
Brian Hampton
| Posted: Mon Mar 31, 2008 3:06 pm Post subject: |
HI,
Nice work...
Some questions...
1) Do you have AKB dis-abled on the G70?
2) Since you're using the HFCR sensor... I assume you're using HFCR however,.. While it looks like it ... it's somewhat different. So,... Is that HFCR?
3) If it is HFCR... How did you ask it to start at 7.5IRE instead of 0 and how did you measure that data point. (Did you just alter the measured values after the measurements were taken?)
Thanks,... I love HFCR and even the 709 disc. I'm using a Spyder II that I got for about $80 new at some point. I compared it's readings to an EyeOne (?) sensor belonging to someone on AVS and they responded identically which is one reason I'm not itching to replace it as my color meter.
-Brian
Brian Hampton
| Posted: Mon Mar 31, 2008 9:09 pm Post subject: |
Quote "Who needs Gamma Correction?"
Bruce Banner?
MikeEby
| Posted: Mon Mar 31, 2008 9:11 pm Post subject: |
| Brian Hampton wrote: | Quote "Who needs Gamma Correction?"
Bruce Banner? |
LOL
AFryia
| Posted: Tue Apr 01, 2008 1:07 am Post subject: |
| Brian Hampton wrote: | HI,
No, I have it enabled. On 16:9 material it is hardly noticable.
HFCR yes. I adjusted the display properties to "XP" It changes the default colors and icons I assume. I believe I have the latest version 2.0.1
Those are the data points as measured, none were altered. Under the tab Measures->Generator->Configure->Grey scale GDI set it to 16-235 for video material.
AFryia
| Posted: Tue Apr 01, 2008 1:17 am Post subject: |
| kal wrote: | Some questions:
I don't know. Chris Wiggles says 2.5, others say 2.22. all I know for sure is my PJ looks a hell of a lot better now at ~2.2 then it did at 1.9. I was getting readings in the 2.35-2.38 range I'll need to make another custom color and try and get 2.5
| kal wrote: |
Delta E is the deviation from the target color. In this case grey scale. The smaller the number the better.
A color shift less than 3 is considered undetectable I believe.
