Harvey
Joined: 02 Mar 2008 Posts: 66 Location: Germany Lennestadt NRW
| Posted: Thu Mar 20, 2008 8:20 am Post subject: HS-Board Error or have i made a mistake on Zenith Pro 851X |
Now the Board is here and i test it without conectet the HS and the Other Wire that comes out of it with high Voltage )
The Power was vor about 5 Sec on and i heer a sound out of the Cabel so that it sounds like high Voltage..
I thought wou everything is fine you can fix now all together and start But then the Power Supply went down and
after disconect the HS Driver Transistor i see on my multimeter that it has schorten ...
Why Is it possibel that i made a mistake conecting not all the leads to its Part´s
I only left off the leads that are for High voltage..
bevor i schorten other HS Transistors pleas tell me if i can test without conecting HS or better conect HS and leave only the screen wire of the Tubes off its Place.
_________________ .....Was nicht geht läuft irgendwann...
.......lieber 5 mal löten als einmal.......
Harvey
| Posted: Thu Mar 20, 2008 10:50 am Post subject: Now the HS is working and a other Problem has come in Place |
Now the HS Board and the Suply Bord are changed...
On the Red and Blue Tube ist a Box with letters in it ( i can not clearly see it because i am not in Focus) 8)
On the Green Tube letters without a Box or only Part´s of Letters are shown.. 8)
So the Green Tube drifts in Focus from sharp to unsharp then a Click Noise i thing a little Thunder and then the sharpness comes back..
So the first Problem is the drift of the green Focus..
So the second Problem much more dificult i think is that this Picture after a wile goes over to a Noise (not loud)
an the Screen become brighter and the image drift´s on all tubes to the right and gets smaller and scratching is schown
on the screen . .. after this i pull the Plug out and wait a Moment ...
The Plug in and the same Prozess begins a clear Picture with a drift in green Focus and the the totali loos of the clear Picture and a scratching to one side on all Tubes and a little noise but i thing that the Noise is from the deflektion´s
because of the lost of Syncronisitie..
Can anybody tell me what in hell is to do or better let it and disasemble the Projector and trough the rest away
Harvey
| Posted: Thu Mar 20, 2008 1:37 pm Post subject: |
I have the old Style .. I have ask you several Times if i must jange the Block....
Now what is the Price of the new Style Focus Block and whats about the other Problem with the Power Suply i think.
Harvey
| Posted: Thu Mar 20, 2008 1:38 pm Post subject: |
change is the right word please look over my bad english
Harvey
| Posted: Thu Mar 20, 2008 1:40 pm Post subject: |
about the second Problem ... when i let the Plug in and switch only off per remote control then wait a wile and switch on again the error with the Picture comes directly..
| Posted: Thu Mar 20, 2008 2:10 pm Post subject: |
Well without getting the HV to fire up, we didn't know that the focus block was actually bad. With the low value of the set, there's no point in buying stuff you didn't need.
The focus block is expensive, $250 incl air shipping. I do have stock.
Cheers!
Harvey
| Posted: Thu Mar 20, 2008 4:20 pm Post subject: |
That´s right Curt ... now i fix that Problem with a Focus set of a Grundig TV it´s fine now..
But what about the second Problem do you have a Tip where i can surch for the Error..
Harvey
| Posted: Sat Mar 22, 2008 9:32 pm Post subject: |
So everything works we can try now you have PM Curt.
Harvey
| Posted: Mon Mar 24, 2008 9:53 am Post subject: Never run power on HS Board without conection HS Wires... |
To all techniks never put power on a HS Block without conectet the HS Lead´s
It will damage the Board and the Transistor...
The second Problem was that i had no input signal conected
| Posted: Mon Mar 24, 2008 12:43 pm Post subject: |
Sorry, I was in and out this weekend, took some time off, so everything is working now?
Harvey
| Posted: Mon Mar 24, 2008 12:51 pm Post subject: |
You have PM Curt 8)
