Barco RS 232 control questions
Posted: Mon Mar 17, 2008 3:15 pm    Post subject: Barco RS 232 control questions
I sold a planetarium a late model Barco 708 to replace a Barco 700 that was dying. Everything works fine, except the remote RS 232 control. It does nothing.
Assuming that the computer/control cable is still OK, did the software change?
This is an area I have no experience in, I thought that the software controls remained unchanged through the range of Barcos...
Posted: Mon Mar 17, 2008 3:30 pm    Post subject:
Hope to try the RS232 port on my BD 808 tonight but you should be following the programming a Crestron part 2 thread. You might need it ...
https://www.curtpalme.com/forum_archived/viewtopic.php@t=8856.html
As far as I know you are correct. The software should be the same.
Posted: Mon Mar 17, 2008 3:43 pm    Post subject: Re: Barco RS 232 control questions
Addresses still have to be set even with the control software.
