Tube lights without heater connected ??????
voodoo7869
Posted: Sun Mar 16, 2008 10:07 pm    Post subject: Tube lights without heater connected ??????
Should the raster of the tube light without the heater voltace connected?
What would cause this?
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Posted: Sun Mar 16, 2008 10:10 pm    Post subject:
I wonder if you have your G2 connection on the right pin?
did you try the suggestions on the other post?
voodoo7869
Posted: Sun Mar 16, 2008 10:13 pm    Post subject:
yes i did I have lugs in a marquee and the other 2 are fine that is why i am so confused. I have tried swapping the vnb from a good tube to this one and still the same thing. what is wierd none of the other tubes light without the heater connected. so i am at a loss
voodoo7869
Posted: Sun Mar 16, 2008 10:25 pm    Post subject:
I was looking at other threads could it be contamination?
I think curt had a problem with a tube a while ago.
If so how would you burn this off?
I have read about it and would like to know how to do it.
Thank you to all for your help.
now I am wondering if the tube is bad, shorted inside. do you have another tube to try? you dont have to install it , I test tubes by swinging down the back heat sink, i put something over it like a long pice of foam and then lay the tube onto it then connect all the leads to it. fire up the projector and see if it happens on that tube as well. if it doesnt then you have a bad tube.
Posted: Sun Mar 16, 2008 10:27 pm    Post subject:
I think you turn up g2 pretty high on that tube and let it run to see what happens, look at Cliffs meet thread, it has it on there.
found the post
http://www.avsforum.com/avs-vb/showthread.php?t=995618&highlight=tube+failure
voodoo7869
Posted: Sun Mar 16, 2008 10:46 pm    Post subject:
I read the post i will be trying it now wish me luck.
voodoo7869
Posted: Sun Mar 16, 2008 11:06 pm    Post subject:
woo hoo all fixed now all i need is a new hv splitter (on its way) and fix a streaking problem on a neck card then i can finally post my pics of the lugs.
The fix was i ramped the g2 up to like 60 on the pj then tapped the lc housing with a hammer and i heard a pop then all good. Twisted Evil
Posted: Sun Mar 16, 2008 11:51 pm    Post subject:
Did you at least cringe before taking a BFH to it? Shocked
voodoo7869
Posted: Mon Mar 17, 2008 12:20 am    Post subject:
just a little but it worked so it was worth it. I promise I was gentle Twisted Evil Mr. Green
Posted: Mon Mar 17, 2008 12:42 am    Post subject:
Glad you got it fixed!
