help with set up barco graphics 800
n733
Posted: Fri Mar 14, 2008 7:29 pm    Post subject: help with set up barco graphics 800
Hi im a crt noob and i recently recived my moome ext box. Just wanted to ask if anyone near me might help me set up my barco.. i live in porterville california about 40min away from bakersfield and 1hr (on a good day) away from fresno....Any help is welcomed....
Posted: Fri Mar 14, 2008 7:35 pm    Post subject:
You may want to define what you mean by "help me set up my Barco".
Ie: What's done and what isn't, and what you expect. Is the Barco sitting in a corner never turned on and needs to be ceiling mounted, physically aligned, etc? Or is it already mounted in the right spot with the right toe-in and sheimphlug set and you need someone to help with with converging a specific input frequency? Something else?
n733
Posted: Fri Mar 14, 2008 8:24 pm    Post subject:
hi kal sorry, i guess i did not give my 2nd post that much thought..Here goes its table mounted with a 92in screen i had it set up at 720p looked decent to my eye's i want to do 1080i and i just want to be sure that i can get the most out of it performance wise. Its got only 725hrs on what appears to be new tubes...I am willing to compensate for the drive $$$..
Posted: Fri Mar 14, 2008 9:30 pm    Post subject:
A completely in-depth setup from start to finish including working on the magnetics could take someone all day or not two days. Probably not worth it for a 800 unless it's your own, or you're paying an expert. Smile When I replaced my Barco 800 with a Cine 8, I spent about 20 hours total setting it up from scratch after it was on the ceiling in the exact right spot. But then, I'm fussy and I spent quite a bit of time on the magnetics.
You likely just need someone to spend an hour tweaking it nicely however - someone who's fast can get 80% of the performance out of the thing in about an hour if they're in a hurry.
Is it table mounted for good? If there's a chance it's not in the final resting spot (or even be knocked around slightly) there's no point in doing a nice setup as slight movements of the projector relative to the screen will completely throw those off.
Barco 800's are really easy to set up if you just follow the on-screen guide.
If you want to take it to the next level, check out Guy Kuo's general CRT setup guide here: http://www.curtpalme.com/Focus_and_Mechanical_Aim1.shtm
Hopefully someone around your neck of the woods can find a few hours to lend you hand if you need it.
