Stig playing up. Anyone with an 8500 want to test for me?
listenlounge
Posted: Sun Mar 09, 2008 6:47 am    Post subject: Stig playing up. Anyone with an 8500 want to test for me?
Howdy partners!
Some time ago, I purchased from curt all the components needed to upgrade my Marquee 8000 to an 8500. Curt had my rear heatsink and clm and ran it in a test machine he had. All worked out fine. When it returned to the sunny shores of OZ, and was installed in my machine, the setup menu shows the Stig Waveform Board as "Not installed"
Have tried reseating everything etc etc.
It's been a while now and I have done nothing about it.
Before I send it back to Curt to test can someone please do the following for me...
1. TELL ME WHAT IS WRONG or
2. Remove the ribbon cable from the Convergence board (basically disconnecting the stig amp from the waveform board)and start up your Quee.
3. Then see if the SWB shows as installed or not. If yes - then I only need to send Curt my CLM. If no, then I need to send him my heatsink too. I want to know if the CLM will recognise the SWB without the amp attached.
Many Thanks
Ben
Posted: Sun Mar 09, 2008 4:46 pm    Post subject:
Hello
I will try to run that test for you. Question is.........do you Have a Stigwave Board installed? What firmware version on your control board?
Posted: Sun Mar 09, 2008 5:57 pm    Post subject:
Yes check to see if there are two bopards connected to your CLM one is the Deflection Processor board the other is the stigwaveform board, the latter is the one you need.
Posted: Sun Mar 09, 2008 10:20 pm    Post subject:
Hello
My 8500 shop tester did enter Stig routine with the ribbon cable disconnected.
listenlounge
Posted: Sun Mar 09, 2008 10:25 pm    Post subject:
Hi guys,
SWB is installed. I have unseated and reseated after cleaning the contacts.
Board number on SWB is 50-2010-02P
CLM - hmmm its been a while since I played with it, so I do not know which IC's to give you the versions for.
U16 is 1.5
U44 is 1.0
U45 is 1.3
U35 is 2.0
Curt had this board working as is in a test machine with my heatsink. It was working in canada, but won't go in AU.
Perhaps the SWB is racist against us Australians......
Ben
Posted: Sun Mar 09, 2008 10:31 pm    Post subject:
Aha!!!! U35 i don't think is anew enough software for astig, Tim would know what version U35 should be.
listenlounge
Posted: Sun Mar 09, 2008 10:32 pm    Post subject:
Thanks Tim.
I will send Curt my CLM.
Any other ideas to try before I post?
Cheers
Ben
listenlounge
Posted: Sun Mar 09, 2008 10:33 pm    Post subject:
Hi Athanasios,
I wondered that, but Curt had it running already.
Strange.
Ben
Posted: Sun Mar 09, 2008 10:34 pm    Post subject:
Hello
The first 9000s had zone stig enabled at v2.0 so I think you have a control board issue.
Posted: Sun Mar 09, 2008 10:36 pm    Post subject:
let me go check my marquee 800 it has the vesion 2 software i dont have astig coils but i do have an astig wave form board from my other pj, that doesnt have astig coils either but i know it showed up on that software with u35 as version 4.
be right back
Ok forget my above post Very Happy
