Protection for phone, cable and ethernet connections.
Posted: Sat Mar 08, 2008 10:26 am    Post subject: Protection for phone, cable and ethernet connections.
I'm fairly sure I've solved all of my (power related) protection issues with the recent installation of a giant APC "Smart UPS" in my rack for my home theater and automation system. This UPS not only takes over in the event of a power outtage, it senses above and below user definable voltage parameters with features called "Smart boost and Smart trim" to protect it both ways. Through RS232 connections, it communicates with my Crestron system and triggers a safe shut-down of my whole system, including the projector if power is not restored within a user definable period (I chose 5 minutes). The UPS will hold everything in standby until the batteries are down to 15% or the power is restored. At 15% the UPS shuts down. When power is restored, the UPS comes back to life and the rack goes back to standby status. All user screens on the touch panel have a indicator telling you if you are on back-up power or on-line. You could be in the theater, have up to a 5 minute power outtage and not even know it. However the phone, cable and ethernet lines have no protection. Who makes a device that will handle just those issues? Thanks,
Harvey
Posted: Sun Mar 09, 2008 9:47 am    Post subject:
Very Happy Everyone everywhere look at the Page of www.dehn.de...
I thing you find what you need there .. I can purchase this Part´s you need and send them to you..
I am a customer of Dehn Elektrik and i have a Service Center near Cologn www.harvey-electronics.de
I can order and send you the Part´s to Protect Phone and Ethernet Line...
You Idea with the UPS is very good can you tel me how you managed the switsch to standby on it..
I have a UPS 1400 APC with a 9 pin conector what is to do to tell the Projector to go to standby...
I am very interestet in your answer.. Thanks J.Haverland
Who find´s errors in my writing can hold them Smile)) Thumbs Up
.....Was nicht geht läuft irgendwann...
.......lieber 5 mal löten als einmal.......
Posted: Sun Mar 09, 2008 10:56 am    Post subject:
If it is a "Smart UPS" that you have, APC provides software for free (Power Chute) that you can install on a PC to protect it. It won't shut down other devices. Crestron automation systems has a module that I was able to use in my system along with some additional programming. The module detects that the UPS is on battery back-up and creates a simulated led on my touch panel. I took that signal, added some additional programming to to begin a event. When my additional programming detects that signal, it waits 5 minutes and presses the master power off button on my touch panel. The master power off button shuts off all the equipment in my rack system. Simple Wink My solution is only of use to someone with a Crestron automation system. I probably should not have used the term "stand-by" as the whole home theater is now safely in the off condition.
lyd
Posted: Sun Mar 09, 2008 2:03 pm    Post subject:
Cylix makes the sort of dedicated communication line protection you're asking about, which I reference only because I have used (not purchased -- it was in a work environment) their stuff before, but so does APC and probably Triplite and the rest of the usual suspects.
Maybe you are trying to make this too difficult, though? How about just getting a power strip with phone, ethernet and coax ports, then running your comm lines through that?
~$30 and you're done. Plug it in to an outlet for grounding and don't use the outlets on the strip if you prefer not, you're still at least $50 ahead of where you'd be if you buy separate solutions for phone, catv and ethernet.
*shrug* Either way, there you go. Wink
lyd
de gustibus non disputandum
