How clean a crt glycol chamber?
rds
Posted: Thu Mar 06, 2008 3:44 pm    Post subject: How clean a crt glycol chamber?
Hi all,
Currently have a barco gr 808s with colored glycol in the red and green crt.
Today buy a set of hd8 color corected lenses and need clean the colored glycon and put the clear glycol again.
How clean the chamber to put the clear glycol, wather, alcohol, or?
Thanks!
Rubén
Posted: Thu Mar 06, 2008 3:51 pm    Post subject:
The HD-8's you bought... are they color corrected or color filtered? If just color corrected, you certainly won't want to replace your colored glycol with clear.
I'm not sure I've ever seen color-filtered HD-8's before. Note, I'm not saying they don't exist, I just don't recall seeing them before.
EDIT - There are lots of threads on cleaning coolant chambers if you need to do that. Search glycol, fungus, clean, etc.
Posted: Thu Mar 06, 2008 4:04 pm    Post subject:
http://www.curtpalme.com/Fungus_Removal1.shtm
I'll give this one to ya fo free. The next one is gonna cost ya.
Remember Search is your friend. Thumbs Up
rds
Posted: Thu Mar 06, 2008 5:19 pm    Post subject:
Hi Guys,
The lenses are from a Runco dtv 992ultra,
Anyone know if need change the colored gycol or no?
Thanks for the link!
Rubén
CRT_Ben
Posted: Thu Mar 06, 2008 5:32 pm    Post subject:
rds wrote:
Hi Guys,
Rubén
Ooookayyy. Look through the red lens. Does the world look red? If yes, you need clear glycol. Look through the green lens. Does the world look green? If yes, you need clear glycol. Not rocket science, here, you can't double up on the color filtering, either the lens or the glycol, but not both.
rds
Posted: Thu Mar 06, 2008 6:25 pm    Post subject:
Hi , Yes the lenses are red and green and the blue is clear.
Thanks!
Rubén
Dave Lister
Posted: Fri Mar 07, 2008 3:45 am    Post subject:
Save the old coloured glycol if it is still good as someone may want to buy it to replace their glycol as coloured glycol is hard to get.
Stuff for sale;
Fujifrontier
Posted: Fri Mar 07, 2008 4:40 am    Post subject:
what would you filter it thru
Posted: Fri Mar 07, 2008 4:42 am    Post subject:
I've used cheesecloth on car coolant glycol with good sucess. Used a few layer's.
Coffe filter's didn't work, tried that too.
rds
Posted: Fri Mar 07, 2008 6:49 pm    Post subject:
Hi guys,
If anyone need the colored glycol I send you free only shiping charges.
I am not sure if is equal to the original, the red is perfect, the green a bit soft, based on pictures.
Rubén
