marquee 9" rear tube mounting plate
Posted: Wed Mar 05, 2008 9:32 pm    Post subject: marquee 9" rear tube mounting plate
does anyone have a schematic for this part, or one I could borrow for a few days? It seems there have been a lot of 8500LCs that could use 9 inch tubes except for this major stumbling block. I'm thinking of simply hogging them out of billet on a CNC mill and then anodizing.
nuttall_chris
Posted: Wed Mar 05, 2008 9:37 pm    Post subject:
If your looking to upgrade an 8500LC to a 9500LC, I have a complete set of 9" Marqee housings with busted tubes in them. Make me an offer.
Chris.
Ile
Posted: Fri Mar 07, 2008 2:41 pm    Post subject:
I think you have to make two different plates for one projector, least for AC Marquee.
I made two bit simplified set of those plates using hand tools and almost made drawings. But then I though that nobody else wouldn't make those anyway, because VDC sels those for $120 or something...
Posted: Fri Mar 07, 2008 4:44 pm    Post subject:
i'm not talking about the upper and lower tube assembly mounting plates. I'm talking about the back half of the LC chamber. Looksl ike i'll be be buying a set from Chris anyway so I doubt I will machine any.
Posted: Sun Sep 14, 2008 4:24 am    Post subject:
I need a set of those, still thinking of machining them?
speedyandre
Posted: Sun Sep 14, 2008 10:58 am    Post subject:
My 9500LC housings are available too, I think I'll stick with Sony after the debacle with my fried tubes Crying or Very sad
André
I'll be broke
Heywood Jablome
Posted: Sun Sep 14, 2008 12:01 pm    Post subject:
I've got a clean one, with C element (clear) and without tube, which belongs to Chip (stefuel.) If anyone wants to take up the challenge of reverse-engineering a mount PM him and ask to borrow it, I'll ship it if he's willing to share.
Posted: Sun Sep 14, 2008 1:09 pm    Post subject:
I have not had a 8500LC in my hands but why couldn't you just set one up in a CNC or plain old milling maching and hog it out to 9" measuements. If someone wants to send me a 8500LC coupling, I could drop it off along with one of my 9500 couplings at a friends shop down the street from me and see if he can do it.
Posted: Sun Sep 14, 2008 1:29 pm    Post subject:
I could remove the tube and send you the back plate, how much do you think it cost to be done?
Posted: Sun Sep 14, 2008 2:21 pm    Post subject:
I assume the first thing would be to compare it to one from a 9500 to see if there is enough meat to hog out. My brother-in-law is a CNC programmer. If he can establish the coordinates using a 9500 blank and save them to a data base it might be as simple as dropping the 8500 on the table and let-er rip. My friend down the street has a regular milling maching in his basement. I have no idea what either would charge.
Posted: Sun Sep 14, 2008 3:15 pm    Post subject:
Hmmm woulnd't the milling machine cut that 8500 to shreds Laughing a little at a time?
Posted: Sun Sep 14, 2008 3:34 pm    Post subject:
I don't think it's doable, they're cast pieces and are not any larger than they need to be. I wish we could find that pic someone posted of both pieces side by side, the 8500Lc back-plate is much smaller.
Also, the front plate isn't machineable from a cost effectiveness POV, you would need to start with a solid block of AL 10 inches square and that's nuts. However maching the back plates could have one huge advanatge, those crappy little fill hoes could be re-designed and then have the whole thing Anodized (coated) to prevent the common corrosion problem.
Posted: Sun Sep 14, 2008 4:36 pm    Post subject:
Who cares as long as it's not a AmPro Wink
nuttall_chris
Posted: Sun Sep 14, 2008 4:42 pm    Post subject:
Her you go.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=1612.html
Posted: Sun Sep 14, 2008 4:51 pm    Post subject:
Guys!
I have maybe ten complete spent nine inch tube assemblies here, no yokes or covers, $100 and shipping. Trying to machine an 8" LC plate risks tearing the bellows to get it apart.
zGman
Posted: Sun Sep 14, 2008 4:59 pm    Post subject:
The 9" tube mounting plate is actually made in two parts, glued and screwed together.
The machine work to duplicate this piece would far exceed the cost to get a set from Tim.
Actually just getting the raw aluminum billets would probably put you out of the ballpark....
G
Posted: Sun Sep 14, 2008 5:26 pm    Post subject:
nuttall_chris wrote:
Her you go.
Well that blows the crap out of my idea Laughing
