OT Ground Loop
unkyjoesa
Posted: Sat Mar 01, 2008 8:19 pm    Post subject: OT Ground Loop
Greetings all,
I just recently got a component cable for my Xbox and when I plug it in to the back of the Xbox I get a humming from my amp.
I have replaced the cables to the amp, tried plugging the xbox into another circuit you name it I cant seem to get rid of the buzzing, I guess I could invest in one of those cheap GL Isolaters but before spending the money I wanted some advice.
THanks in advance.
_____________________________________
Marquee 8500 w mods done.
DirecTV HDDVR 720p
Moome Component Card
SageTV 1tb storage for ripped DVD's-Music-Photos
Hauppauge Media Extender for SD TV
SageTV HD Extender for the PJ
Xbox Media Center for the PJ
Mits 56 RPTV in Living Room-
No DRM-Ever!
My newest edition Optoma HD65- Dont Laugh at me!
Posted: Sat Mar 01, 2008 10:27 pm    Post subject:
Are the A/C plugs on the amp and Xbox 2 or 3 prong?
lyd
Posted: Sat Mar 01, 2008 10:44 pm    Post subject: Re: OT Ground Loop
You want the amp, xbox and display to all be plugged into the same circuit, preferably the same outlet/power strip.
lyd
de gustibus non disputandum
unkyjoesa
Posted: Sun Mar 02, 2008 12:08 am    Post subject:
MacGyver:
Xbox is the two prong plug with the Microsoft plug, I think it was issued to correct power problems with the Xbox, it has the little reset buttons on it and a green light.
The Amp is a two prong plug.
The Projector and Xbox are plugged into the same PS.
The AMP is in the equip closet and plugged into a very large TrippLite battery backup unit.
What is odd, I can unplug the Xbox from the PS and the buzz is less but still there. Only when I unplug the connector cable from the back of the Xbox does the buzz disappear. The projector doesn't even need to be plugged in and I still get the buzz.
Weired.
DirecTV HDDVR 720p
No DRM-Ever!
Posted: Sun Mar 02, 2008 12:23 am    Post subject:
Sounds more like a feedback issue then a ground loop issue. Did you try the amp plugged into an outlet without the battery backup? Also when you say, I can unplug the Xbox from the PS and the buzz is less but still there, do you mean you unplug the A/C from the outlet or the power supply cable from the Xbox? Last when you say, I unplug the connector cable from the back of the Xbox does the buzz disappear, do you mean the cable from the power supply or the cable to the amp?
lyd
Posted: Sun Mar 02, 2008 12:43 am    Post subject:
How is your sat box connected into all of this, and what happens when you disconnect it?
For that matter, other than the projector, are there any other devices that have a ground to earth connected to anything?
lyd
Posted: Sun Mar 02, 2008 6:12 am    Post subject:
Read this.
http://www.epanorama.net/documents/groundloop/index.html
voodoo7869
Posted: Sun Mar 02, 2008 9:29 am    Post subject:
just feed the amp optical and no feed back at all. Wink
have you tried a different componant cable?
xbox 360 has a floating ground setup so feedback is possiable to standard ground systems.
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Posted: Sun Mar 02, 2008 4:08 pm    Post subject:
This is my assumption also which is why I said probably feedback. The Xbox power transformer isolates the device from A/C current thereby not ground loop. Do you have another cable to connect the Xbox to the amp? Poor ground in the cable can cause noise. Having repaired many A/V recievers and power amps I have found poor solder joints on the RCA jacks cause audio hum which indicates a poor connection can cause this problem. I see where you say you tried other inputs on the amp so thats probably not the case.
unkyjoesa
Posted: Sun Mar 02, 2008 8:18 pm    Post subject:
I have an Xbox, not a 360.
I have tried two different component cables for the Xbox from 2 different manufacturers, the SAT receiver is plugged into a different amp than this one is.
Like I said, when I pull the component cable from the back of the Xbox the buzz goes away. Whether the Xbox is plugged into the power or not, this is what is so weird, perhaps there is a bad solder joint on the Xbox plug itself internally.
I dont think it is a ground loop issue as much as it perhaps might be a connector problem with the Xbox itself.
What do you all think? Tear open the Xbox and check the connector?
Thanks for the help.
DirecTV HDDVR 720p
No DRM-Ever!
Posted: Sun Mar 02, 2008 8:45 pm    Post subject:
Have you tried with just the audio wires connected and the component wires not connected?
Is this your cable?
 Filesize:  10.54 KB
 Viewed:  5035 Time(s)
unkyjoesa
Posted: Tue Mar 04, 2008 3:36 am    Post subject:
Ok, I'm stupid, I had the plug in upside down.
Polarity does matter, and the Xbox plud does not have different sized plugs they are the same so I had the neutral and the hot reversed, I turned the plug around and whala no buzz!
Macgyver, I have the $20 component cable with the thicker high quality wire. I had that cable initially and it was a nightmare, the picture was horrible, like using zip cable instead of a higher quality cable.
Thanks to all of you for your help, and why the hell arent those spades a different size to prevent morons like myself from flipping them around? Rolling Eyes
DirecTV HDDVR 720p
No DRM-Ever!
voodoo7869
Posted: Tue Mar 04, 2008 7:13 pm    Post subject:
that makes zero sense at all. By definition ac current flows bolth ways. so flipping the power cable around makes no difference. you probably have a faulty connection in the xbox. check the solder points on the input plug. The only way this could possiably have an effect is that you have an out of balance neutral in the outlet you are using.
What i mean by that is you have to high of an amperage difference between the neutral and the ground at the main panel.
the difference should be no more than 5 amps and that is pushing it for best noise rejection. it is a really comon problem because in construction they often use one neutral for 2 to 3 hots. I had several circuts that were out of balance. and it does create noise.
unkyjoesa
Posted: Wed Mar 05, 2008 2:33 am    Post subject:
VooDoo; It's back.
Time to take apart the Xbox and fix the connector, I took the unit out of the environment it was in and moved it to another TV and amp and had the same problem.
I am going to clean the connectors first, manufacturers are so fond of these gold plated connectors without realizing that the connectors on the unit are a different type of metal, and what do dis-similar metals do to one another? The corrode or oxidize.
I will let you all know what I found.
DirecTV HDDVR 720p
No DRM-Ever!
voodoo7869
Posted: Wed Mar 05, 2008 2:53 am    Post subject:
please do that would be great
