Astigmatism Adjustment for Barco Data 650
pat
Posted: Sat Mar 01, 2008 8:17 am    Post subject: Astigmatism Adjustment for Barco Data 650
Hello together,
I've got difficulties adjusting the Astigmatism for my CRT.
I found the article in the advanced procedures section but this doesn't help me, because the tubes are different
from the described.
I made some photos from the green tube with an extract from the tube replacement manual.
Can anybody tell me which ring/magnet is for which adjustment (PM Stigmator, 2-pole magnet) ?
Do the white rings have any function (or how should I use them) ?
Greetings
Pat
 Filesize:  297.96 KB
 Viewed:  3459 Time(s)
pat
Posted: Tue Mar 04, 2008 5:05 pm    Post subject:
No one any idea ? Is that CRT to old ?? Wink
Posted: Tue Mar 04, 2008 5:29 pm    Post subject:
It almost looks like the shafts have been taken off? NOrmally missing shafts means a dummy set of rings that don't do anything.
Person99
Posted: Tue Mar 04, 2008 5:34 pm    Post subject:
What Curt said. Those little which clips with a "U" in them should have a knob sticking out of them. That is how you spin the rings with teeth in different directions (which is what causes the magnetic field to vary direction).
Posted: Tue Mar 04, 2008 6:13 pm    Post subject:
I've got lots of 4 pole spares. If your dots flare out evenly though, then you're fine, and you don' t need new astig magnets.
pat
Posted: Tue Mar 04, 2008 7:43 pm    Post subject:
Thank you for the answers.
It seems that the knobs are missing. No one of the tubes does have such a knob.
However, if i adjust eg. "BA" then the flare moves its position.
So my problem is what is "2-Pole" and what is "PM Stigmator" and what the "2-pole magnet" ?
If I follow the instruction here: http://www.curtpalme.com/Astig.shtm
....The pair of tabs/magnets closest to the CRT socket are called the 2 pole magnets and have the most affect on astigmatism. The second set closest to the lens are the 4 pole ones, and are more or less a fine tuning of the 2 pole ones. The 6 pole magnets on some projectors are an even finer tuning of astig....
So "BA" should be the 2 pole magnets. But is "4 pole" = "PM Stigmator" and/or do I have a 6 pole magnets for finer tuning ? Confused
Greetings
Pat
