RCVDS 05 Problem
RobinReumers
Posted: Tue Feb 26, 2008 7:38 pm    Post subject: RCVDS 05 Problem
We have a problem with our RCVDS 05 connected to a Barco 1208s, we've never used it since buying it from Ebay about a year ago! This puts us in an akward position to return it. When it fires up, the is an LED with "-" showing, and that's all it does, all buttons on the front panel won't work. If I try to select a source on the projector, it says Communication Error! We've connected it to Port 1 on the projector (which says 800-peripheral), is there anything we're missing or how could we debug this?
Robin
jask
Posted: Tue Feb 26, 2008 8:24 pm    Post subject:
download the manual for your projector from the set-up tips and manuals section, the connections for your switcher are illustrated.
kschmit2
Here's a link to the RCVDS-05 Owner's Manual:
http://lix.in/bcbbfe8b
Maybe Kal can add it to the Barco page (with Curt's permission).
Kai
scoobydoo
Posted: Tue Feb 26, 2008 8:43 pm    Post subject:
hey Robin
what are you running out the back end to the projector? I can't remember what port 1 is.
I can check mine when I get home tonight.
when is shows "-" is just means thats you haven't choosen a port yet? I have mine on 5 so to get that it would be 05
if you have a barco remote it will work on the unit as well.
RobinReumers
Posted: Tue Feb 26, 2008 9:31 pm    Post subject:
Thanks everybody, I'll have to check it tomorrow. And thank you so much for the owners manual, that helps a lot as I couldn't find it anywhere!
Robin
scoobydoo
Posted: Wed Feb 27, 2008 1:06 am    Post subject:
Robin
what type of input are you using and output?
mine has a variety but i'm using rbghv in and out
Gino
Posted: Wed Feb 27, 2008 10:13 pm    Post subject:
What are these things going for these days? I have one sitting in the garage doing nothing.
secstate
Posted: Mon Mar 03, 2008 9:23 pm    Post subject:
I have seen them go for $25-100 US on Ebay, all depending on the types and number of cards installed. It has been a while since I have seen one hit a $100 but they are fewer and far between than 12 months ago.
