Interesting HDMI cable supporter
Posted: Fri Feb 22, 2008 5:08 am    Post subject: Interesting HDMI cable supporter
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=181-729
Guess the finaly figured out that HDMI cable connectors suck and brought a handy device to market.
I wonder if it works with all devices?
KrisRoberts
Posted: Fri Feb 22, 2008 5:54 am    Post subject:
The sad thing for me is: # Works with Dayton Audio Signature Series HDMI cable only
But maybe someone will figure out a more general solution.
voodoo7869
Posted: Fri Feb 22, 2008 8:09 am    Post subject:
I know a solution already 5 min epoxy Twisted Evil Mr. Green just glue it to the end of the cable it will still do the same thing it will not effect the signal quality.
just a thought
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Posted: Fri Feb 22, 2008 11:22 am    Post subject:
I have never had a problem with HDMI cables unplugging themselves. What the heck are all of you people doing, humping your equipment?
charlez
Posted: Fri Feb 22, 2008 2:27 pm    Post subject:
gefen uses it also on some of there products
Posted: Fri Feb 22, 2008 5:27 pm    Post subject:
No ( unless it's a reely sexey reel to reel or an extending tray pop up loading SLH-F700 betamax with motorized drive )
I remember reading about the HDMI connectors snaping off the chasis side when people push their equipment back into their racks. That sucks Thumbs Down
Posted: Fri Feb 22, 2008 6:08 pm    Post subject:
I think it has more to do with custom installations where everything's in pull-out racks. There's no locking mechanism at all on HDMI so if you move things around, the strain is partially at the plug itself instead of completely through a bend in the cable.
Get a long enough cable on there too and will tend to pull on it.
HDMI is one of the stupidest connectors from a physical standpoint. There should be some sort of locking mechanism or screws like with just about everything else (including DVI). Why no screws??
Person99
Posted: Fri Feb 22, 2008 8:42 pm    Post subject:
Why no screws??
To be consumer friendly. Very Happy
