What's the best Extron type box to boost signal?
Posted: Thu Feb 21, 2008 2:34 am    Post subject: What's the best Extron type box to boost signal?
What are the 'good' not so noisey models of Extron that can take a lower signal and boost it? I need to give my Sony PC-1271's output a boost for testing.
Person99
Posted: Thu Feb 21, 2008 3:10 am    Post subject:
The newer the better. I've had good luck with the 202Rxi. the 109 does not have fine adjustment so I would not go that way.
Others have had good luck with the Altinex products.
Posted: Thu Feb 21, 2008 4:28 am    Post subject:
I've been offered an RGB202 plus. Whadda think? Any good?
papalek
Posted: Thu Feb 21, 2008 10:53 am    Post subject:
I had a 202 plus,it worked good till it died. I now use a RGB 300. I like it allot more. The adjustments are much finer.
I do love my AmPro's
Posted: Thu Feb 21, 2008 4:45 pm    Post subject:
Is the RGB300 what you are using to up the signal to your Ampro?
papalek
Posted: Thu Feb 21, 2008 5:20 pm    Post subject:
Yes it is. I split the signal before gets to it so that the Barco Retro 801s does not get the boosted signal.
Person99
Posted: Thu Feb 21, 2008 5:21 pm    Post subject:
I've tried several 202 pluses. Those are pretty old and they have been hit or miss with me. From least to best in the 202 series:
202 plus
202xi
202Rxi
I would not pay more than $12-15 for a 202+ so you could try it and see if any good.
