New Barco 1208/2 issue
KES
Posted: Tue Feb 19, 2008 6:42 pm    Post subject: New Barco 1208/2 issue
OK, I need some help on solving a problem. The Green tube is illumimating, but not projecting the image. I have tried the following with no change. Switched the RGB amplifer, switched the RGB swither card. I can see the image barely when looking into the lens. When I go to the internal adjustment settings the green illuminates fine, but again not with a normal input. I am using port 3 for my input source. Any help on where to go from here would be gratly appreicated.
What does not kill you, makes you stronger.
Posted: Tue Feb 19, 2008 7:11 pm    Post subject:
Sounds like a shorted Green tube... Crying or Very sad
http://www.thegleam.com/ke5fx/crt/sencrt.pdf
Person99
Posted: Tue Feb 19, 2008 8:38 pm    Post subject:
Test port 5. Also, make sure the G2 is correctly set. Lastly, do any frequencies work correctly?
KES
Posted: Tue Feb 19, 2008 11:23 pm    Post subject:
Hmm... if it was a bad green tube....why would I still get a normal green text when I go into the adjustment mode? I would think if the tube is bad.. the text would be out.
I haven't touched any adjustments on the G2. You think the port 3 itself might be out?
Posted: Tue Feb 19, 2008 11:27 pm    Post subject:
Sounds like the tube is fine, I would check port 5 and see if you get an image.
KES
Posted: Tue Feb 19, 2008 11:29 pm    Post subject:
OK, will check port 5 tonight. Got to go to a meeting. Thanks for the input all
KES
Posted: Fri Mar 07, 2008 6:35 pm    Post subject:
How difficult is it to switch out the Port 3? I have a 2nd 1208 available. I connected a composite signal to port 1 and the PJ works fine. So, I believe the problem must be with the port 3.
